Great report Peter. I would love to listen to Christian's system one day...
Me too...
While the RM's make a significant difference....leaving them and the turntable out of the discussion for the moment...it was my optimized speaker setup that was responsible for the majority of the improvement Peter was hearing.
Chris, I might add that moving the listening seat further back probably also contributed to the sound.
It was dull and boring for the first 3 months when I first got and then it opened up suddenly and bloomed to a full bodied rich sound. Still it's far from a neutral cartridge but has beautiful rich tones that melt you on strings along with a sense of space and dimension that make it irresistible for a violin sonata.
david
It wasn't mentioned but Peter was able to hear the effects of active isolation on my AS2000 TT. He preferred the sound w/o active isolation engaged as I was able to toggle the switch on and off while listening to a track. It was clear and obvious to him that active isolation is a detriment to the sound of the AS2000. I had a similar experience with my Clearaudio Master Innovation. (Edit...it was mentioned by Peter....my bad)
Funny comment, Tango. Having now heard the AS2000 and 3012R, I have a clearer idea of what David means when he uses the term "natural". Afterall, he is the one who set up Chris' table and arms for him.
Dear M1,
When you move to the new place, I humbly suggest you try just plugging your amps (better yet the whole system) to the wall bypassing the Torus. The electricity around there shouldn't be so bad or worse than Bangkok. I used to have a big 45 amp Torus too. You might find something interesting that you may even prefer.
Your sincerely,
M2
The Torus were already in the crosshairs but I stopped with the stinky cat litter boxes, we’re waiting for him to moveDear M1,
Your sincerely,
M2
You must be in the mood today master Yoda. I never read you wrote anything to describe sound much more than "natural."This time there are two long lines with many adjectives.
Kindest regards,
Tang
Dear M1,
Your sincerely,
M2
Listening to the several alternatives is surely mandatory. However, for many people in the US using 240 mains , the Torus is not a tweak, it is a significant technical improvement to mains. In the US 240V is delivered as a symmetrical split phase line and using a Torus will effectively cancel most of the common mode noise carried by the power lines. However, I easily accept that sometimes our systems can sound better with noisy power lines ... Many of the tweaks we love are just a kind of noise ...
Sorry for sidetracking the topic but I am getting a Torus avr 30. There are many problems with the electricity where I live. I have a direct conenction to the pole but still the electricity varies about +-10 (220 to 240) and with lots of noise. Having 109db speakers does not help either. I do not need much power, 2 set monoblock, 2 ss class d monoblock, 1 class d sub amp, tt motor, ss phono pre, oppo 105d, bryston bda3 and a passive pre... torus avr 30 will have a lot of headroom.
What is the problem you hear with the Torus?
London has the same problem, voltage fluctuating between 237 to 253 with noise. No idea what the best solution is.
Bonzo, is the General crazy about audiophile power cords and conditioners?
Tang![]()
No but he lives in a nice mansion away from the main city. I don't know what his power condition is. I am not crazy about cords but I need to protect gear from fluctuations
