You mean if someone cooks five different dishes for me to try and I pick to like one is an act of persuasion?
David didn’t say a word to describe sound or play with my head to hear things. We are talking more than a hundred thousand dollars worth of equipments here that I put aside. I don’t think anyone in the right mind would let a person persuade to quit using without hearing and deciding himself.
Hypnotize maybe . Christian was hypnotized to loose his expensive Hezan table too.
Kind regards,
Tang
Tang, That is a very interesting sentence. Since this thread seems to be about sub integration, sub controls, and overall system satisfaction/performance, I'm curious about the order in which David approached the installation of your AS2000. At what point did he suggest you turn off your subs? Did he actually suggest it, or was it your idea alone upon hearing your new turntable in your system? Did he listen to your system before the installation of the new turntable and arm, or did he install the table and arm and then listen and suggest disconnecting the subs? You had lived with the subs for a while and did not notice an issue. Are you saying that David did not have any persuasive comment and "didn't say a word to describe sound or play with (your) head to hear things" when it came to the decision to disconnect your subs?
My audio buddies all have more experience than I do in this hobby. I am usually curious to know their opinions about the sound of my system after some change. They are candid and tell me what they hear. Their powers of persuasion vary, though I always appreciate hearing what they have to say.
When Jim Smith came to voice my system to my room, he spent the first evening simply listening and understanding the sound of my system and my room. He then made two suggestions for changes before he would begin the serious work the next day: dampen the ringing from the upright piano in the corner of the room, and raise the listening seat 3-4 inches. I had not noticed those issues before. My experience and imagination were even more limited at that time. I found Jim to be very persuasive because he has a great deal of both experience and knowledge in this hobby, he is deliberate in his approach, and he has a long track record of helping people. David seems the same way.
