Nothing great about Theta in the day. It was a very foward and bright sounding dac. The Timbre TT1 was way more musical at that time period.
Ok, I never thought the Gen V sounded bright...it had quite powerful bass in fact.
Very organic and dynamic
Like an audio note dac on steroids with a groove pill
The glitch is still there. It is moved away from zero crossing but still there.
Where is the proof that it is not affecting the sound? If the two Yggy's sound the same this is not the proof. If other's think it is bright in version one, where is the proof of the brightness root cause if version 2 sounds the same? Circular argument... It would have to come from either external comparison with other DACs or somehow Moffat would have to make a glitch free version and then see if the brightness is gone (I know you don't think it is bright and I haven't heard it so it is hypothetical to some extent).
It seems you haven't quite paid attention to the comparisons I described.
Same here. The designer of my Schiit Yggdrasil DAC uses a DAC chip, the AD 5791 BRUZ, but nobody else uses it for audio. It's a precision DAC chip for medical devices and miltary applications, among others. The reason not even the manufacturer recommends it for audio is glitch energy at zero crossing. Yet Mike Moffat who designed my DAC wanted to use the DAC chip for its precision, and apparently because it is a current production ladder DAC chip of high resolution (20 bit; the AD1865N is 18 bit). He found a way to address the glitch energy problem, without the usual sample & hold solution which he says sounds bad. The designer of the AD 5791 DAC chip was very astonished that Moffat got it to work for audio (he commented on this on a thread on the head-fi forum if I remember correctly).(...)
I have owned Theta DACs before and can imagine that Mike Moffat still aims at the type of sound he put in his former designs - I must say it was not my cup of tea. However audio is a subjective hobby, if the Yggdrasil matches your system and preference and you are happy with it, great, listen to it and enjoy.
But the decision to use such chip has many other technical problems, and measurements are good but not SOTA - just see the comparison of the spectrum of a 50Hz sinewave, DC–1kHz, at 0dBFS (left channel blue, right red; linear frequency scale) of the Yggdrasil (left) and the Vivaldi (right) (graphs taken from the Stereophile online reviews).
As always, the proof of the pudding is in the eating.
It is meaningless for me. I do not expect recommendations from reviewers, just information and opinions. Many great tube amplifiers have measurements that are much poorer looking. It looks like he needed to counterbalance MF enthusiasm.
(...) Have I ever claimed that the measurements are all perfect? No. Interesting that you find the measurements of the Vivaldi so important, while you dismiss measurements in other cases, like certain tube amps:
Of course, you may say that digital is a different animal than amps. You may have a point, but then the debate arises, to which extent are perfect measurements important for either of them?
Audio Note has a reputation for "go for the emotions and fukk audiophilia vocabulary" sonic signature. Does this hold for their digital lines also?
MSB is frequently referred to as being in a class of its own in digital, taking the crown from dCS.
Anyone familiar with both? What systems have you heard them in? What are the sonic differences?
I am just curious as to why you have limited your choice to these two?
I had the pleasure of hearing a DAC by Computer Audio Design and was astonished by how natural it sounded without any false mushiness - best digital replay I have heard
On the MSB side, I have heard that "Sterile" Jon Valin is about to start marketing the MSB. I am not sure that it is a good or bad thing for MSB...Pretty much every brand that guy touches turns that brand into a very polarizing brand...
Almost arbitrarily. These 2 brands seem to be the "consensus best" right now.
The Great Peter Breuninger, the reviewer whose taste most matches that of Harry Pearson today, has called the Audio Note the best DAC he has ever heard.
Also, Martin Colloms has assigned the Audio Note a CRAZY 450 points on his scale, way above anything else. Colloms happens to be an audio Casanova, and has heard this DAC in many different system contexts, so it makes it an interesting data point... https://www.hificritic.com/digital-audio.html
I guess that's a pretty good pair of recommendations but do bear in mind that in that rarified cost stratosphere, you really ought to be dictating that you get a home audition as opposed to being limited to show auditions, and whilst I am a huge fan of Colloms and Peter - I am sure there must be several components that they both like that you do not - ie in Colloms case he likes a lot of Naim, Linn, and Audio Research quite a bit - for I personally am not a fan. Roy Gregory in his early years of HiFi Plus had a superb ear - but I digress.
All I can usefully add which you probably already know is that this is gonna be a really enjoyable purchase, and I envy you a bit
I meant he introduced a digital offset so the glitch, instead of being at digital zero was moved a little bit away from digital zero. Back in the mists of time, Philips did this with the SAA7220+TDA1541 combination, there's 0x20 added in the filter to move the DAC's glitch away from the zero crossing.
Why don't you go and listen to the MSB at a dealer, or ask for a home audition? And do the same for the Audio Note. Then let us know what you think.
MSB goes to all the shows, and they'll be at Axpona again. Audio Note stopped doing shows, I think, but you can still go the dealer route...
Dealers and shows are as much part of the hobby as are these forums, so unless you have no intention of seeking these products out, and just want to stir sh*t up, an audition will go along nicely with a thread like this.
+1
Instead of just trying to stir the pot with dumb threads.
Gentlemen, I would be very concerned. Valin could destroy your beloved brand.
