I'd get a SGC i7 sonic Transport with a JCAT Femto ethernet card and a LPSU to power the sT and the Femto card.....
And sell those 501's buy my 2 511's.....![]()
One of the reviews out there compares the SGC to the Innuous Zenith
I have been following this thread waiting to see where it goes as I had pretty much narrowed down to the same three. The one + (for me) is that the Zenith has a ripper which I can use, albeit likely only for my initial transfer from my CDs to hard drive, but as the cost of CDs go down and prices of downloads go up (tba) I may just buy the CD and transfer on to HD. This is all about sound though and my experience is that a ripped cd will still sound much better than the equivelent download. The Antipodes CX looks to be a great option too. The distributor sent me the new prices, and availability. $5600.00, available in March (sometime). NO STORAGE. It looks like you will be in for $1100.00 per terabyte. I also found out that even though you can add your own drives, I was told they need to be sourced from Antipodes. Feature wise these two options seem to have the same features/build, but the Zenith has the in memory playback, vs. the Antipodes having HQ Player software. Depending on what you plan on doing with your files wrt upsampling, HQ player may not be important. There seems to be an inconsistency from Mojo regarding HQPlayer, and software in general. At one point he was all for loading Roon/HQplayer and using the combo whether or not you were upsampling, then I think he felt JRiver was the best sounding player. I think the key to Mojo is running AO, which I am very aquanted. Then you got to think about the JCat ethernet/usb. In my system I much prefered Roon direct (no DSP) than with HQplayer in the loop. When I was upsampling everything to DSD 512, HQp was king, but this is moot for me at this stage. If I decide to go Mojo it would likely be with Linux OS because of MSWindows constant updates that invariably cause incompatibility issues between various software that you use. This pretty much puts the Mojo out of contention because I can't wrap my head qround Linux. **** I have not heard any of these units. Based on end user reviews the Zenith and Antipodes are neck/neck. The Zenith seems to be more popular, and there is more info/pro reviews accessible online. I haven't read any reviews or comments that have differentiated the sound differences between the Z se and the Z standard. I believe the difference is silver wire and that Mundorf caps are used in the PSU plus a little more here and there, but not too certain. I think the 'limited' 100 is bologne. It seems that you can always order, but the few dealers I spoke with have one in stock for 'various' reasons. If I had to make a decision right now I would likely get the Standard Zenith with the open mind of getting the SOtM Ultra/Paul Hynes PSU to relieve some of the heavy lifting from the Zenith, run Roon core to SOtM direct to my TotalDac reclocker. I believe this would easily surpass any benifits gained by the 'se' at a lower cost. If I were to go Antipodes, I would apply the same logic and go for the ex @ $4100.00 and add the SOtM/Paul Hynes PSU. Please share your thoughts at this stage. Congrats on the MSB!
Never said anything about doing up-sampling...I have 70,000+ tracks and I gotta say that based on the speed I get now with Roon an i3 or i5 processor isn't going to cut it TODAY let alone down the road as Roon gets fatter. Thinking it is nosier vs. knowing it is are 2 different things. Roon isn't recommending an i7 for no reason....if the Nucleus+ had a loop thru and the Femto card it would be the way to go.....just saying.........
BTW..What are u going to do today with no MSB Roon renderer? I'm waiting for it LOL
Antipodes is a server optimized for USB playback. Have used it with great results at shows. The Master Clock was always in the USB interface, not the server. Never tried the Ethernet version. Why not just buy a renderer and use a computer? There is no advantage to a server IMO with Ethernet.
Steve N.
Empirical Audio
Steve,
Regarding Antipodes, have you looked at the new topology which is designed to isolate and optimize the Ethernet direct to DAC connection in the CX and EX. They were not in my OP because of exactly what you said about USB and that has all change with the new product line coming in March.
Regarding your view about using any old computer and a renderer, why don't you go back to the beginning of this (my) thread and re-read when you tried to make this point the first time. There is an entire world out there which is designing products around direct to DAC ethernet connection using ethernet isolation technique that DISAGREE with your view on this (Melco, Innuos, Fidata, Antipodes, Mojo etc.) Maybe the rapid development by the rest of the market into the Ethernet DAC space is wrong and you are right but I wanna address what they are doing in this thread. Is that ok?
Review for the Innuos Zenith SE (limited edition -- all sold out unfortunately)
http://innuos.com/uploads/cms/Reviews/HiFi+/HIFI+156_Innuos_LR.pdf
I personally found it much easier and cheaper to optimize Ethernet compared to USB. If these devices are much better than a router or WIFI adapter powered from an earth-grounded fast LPS, I will be surprised. I guess I need to try one.
Steve N.
Empirical Audio
Apparently, A/Bs were conducted at the Innuos room (w/ YG/Audio Research/Aqua Formula), between a well broken -in SE and the prototype Statement. And (again, it seems, as I wasn't there), the Statement was clearly quite a bit better, specially in sound staging, with considerable widening and deepening.
Oh well... Hope to have a look at it in Munich!
cheers,
Alex
Alex, I realize you where not there but did you happen to hear if the comparo was USB or Ethernet?
cheers,
Alex
So it is your position that the ethernet isolation topology, linear power supplies, and grounding schemes of the devices I referenced are of no consequence to SQ through a Dac's renderer ethernet port?
Well, I suppose the network isolator will depend on the system.
I bought an EMO HD E70, and it's for sale on WBT at half the price.
It would be interesting to compare the Innuous to Urendu + LPS.
