Martin Logans usually sound bad at a show, and with SS. They can sound thin, lean in the mudbass, even anemic and sometimes a bit plastic. All these qualities disappear when good valves are matched with them, and density is added to the panel. Also they have a narrow sweet spot. At the most the power amp should be the only SS there, though AR 250s seem to be driving these pretty well and Roy Gregory used the Berning quads on his.
Yes, they usually. Yes, they can. But the best sound I ever listened from Martin Logan's was a Mark Levinson complete system (including ML30-31) with Transparent Audio and to Krell's with Martin Logan. Surely in good rooms with space to breath. My apologies for interrupting, Mike.
Mike - without wishing to impose be most curious to hear your thoughts on the Avalon/Spectral room...should your wanderings take you in that direction.
Ked, Have you ever heard a Martin Logan and all Spectral electronic chain system?
Merging Technologies room 7025
quite good sound, and I was impressed with a quad dsd file they played (i had to help them find it on their Roon tablet).....'de Falla' of some sort I think suppose to be on the Native dsd site (which I will acquire). i'm a big dxd and Quad fan, and had an enjoyable talk with these guys about the current state of the highest rez music. they were surprised when I told them that I still preferred my vinyl and tape to my quad and dxd files. I told them they need to get out more.
my initial concern visually in this room was how close the speakers were together. but it worked and the bass was quite even and lively compared to many other rooms. the sound was open and balanced.
Do you know if they're using vintage Altec drivers or new reproduction Mike?
david
Nice pics! I'll post some of my own soon. Did you check out the Verity room? I thought it was excellent.
Manuel de Falla was a Spanish composer that wrote some beautiful classical music, some of it was inspired by the Alhambra gardens in Granada (the South of Spain). Take a look at the Alhambra and you understand immediately why this music is so gorgeous.
Try '3 Cornered Hat' on Decca, it is fantastic..
