The Lampi pictures don't show on my end, really want to see them.
I agree, somehow the attachments above are not visible.The Lampi pictures don't show on my end, really want to see them.
Thanks for the link!
I do not know if its just my PC but your first two posts come through just fine, but the Lampi and ML room picks do not show and the links do not work. Do not know if others are experiencing this or not.
Troy Audio.
never heard them before, but....Wow!
not cheap, but super smooth and extended top end.......quite the sophisticated sound. and really enjoyed talking to designer Francisco Jileta and his son Javier. this is a brand, built in Mexico, that I will be rooting for.
Martin Logan room 1107
the news was the big bad Stromtank battery power and the new D'Ag line of electronics.
sounded just fine. not a big ML fan but these seemed more seamless in the bottom octaves than most ML past experiences.
Martin Logans usually sound bad at a show, and with SS. They can sound thin, lean in the mudbass, even anemic and sometimes a bit plastic. All these qualities disappear when good valves are matched with them, and density is added to the panel. Also they have a narrow sweet spot. At the most the power amp should be the only SS there, though AR 250s seem to be driving these pretty well and Roy Gregory used the Berning quads on his.
