After reading through the Loudspeaker Measurements Explained thread, I thought that maybe someone could answer a question that has been floating in my mind for sometime. If you have two speakers that measure the same, can they sound different?
Just consider the crossover components. Most manufacturers will tune the speaker choosing component types (I am not referring to the values) that do not show in measurements.
Speaker measurements are much less accurate than electronics measurements - manufacturing tolerances and dependence on external parameters is much higher. IMHO, they are much more useful to the manufacturers during development and production than to the consumers.
What audible characteristics of crossover components are immeasurable?
Tim
Other people will have more experience than me, but years ago I helped a friend replacing the capacitors of an old JBL speaker with much better quality ones of the same capacitance. I remember we measured them one by one to keep the values within 2 or 3%. As we did one speaker first, the second after we were able to compare them and they sounded really different.
Recently I compared my Soundlab A1 Px backplates to the so called hot rod level - resistors, capacitors and coils were exchanged by more powerful thick film ones, paper in oil and special coils respectively. The global difference between the sound pre and after is more than what I get changing the medium adjustments by 3dB.
BTW, I did not say the differences are immeasurable. I say that using current, commonly used measuring techniques within normal standard tolerances, these differences do not show significantly in the measurements.
Are you sure? If the differences were that audible - and I don't doubt for a second that they were - a very common on-axis FR measurement should reveal them.
Tim
At the same level the two systems will have the same FR. Says nothing about how linearly either plays (at any volume), what their radiation pattern is, etc. FR is barely a starting point for measurements.
