My cables are on the floor. They don't look neat and they gather a lot of dust. I ordered some elevators.
There was a thread on this very subject ...
..or the more sophisticated...cable escalators
In another forum one fellow suspended his cables with fishing lines hooked to the ceilings.
As stated by microstrip: "metal purity, wire diameter, dielectric type, guard voltage polarization and several other factors that do not show up in measurements change sound, how can you be sure that triboelectric effects (generation of electricity due to friction in dielectrics) is not affecting cables?"We've got effects, too?
What effects?
What are you on at the moment, rsbeck ...?For Hip Hop, use kite string.
There are some excellent clues in all that you've mentioned, Gary. Put it this way, if I didn't worry about the effects you've mentioned I wouldn't be getting the results that I've mentioned in my posts ...At the risk of being ridiculed ...
4 pound test gives you more sparkling highs, 60 lb test is better for your bass.
Best to go with a weave for best sonics over the entire spectrum.
The blue woven fishing line sounds fantastic.
60Lb Test for Bass? More appropriate for Dog Tooth Tuna methinks.
