I am not sure my Big7 can use them or can all of them? I know Mike sent his GG back to Poland and now he can use them.
Mike had a DSD only GG.
What does your test report say on line 24? Update...I see its 545 mv. Should be fine...
Thank you very much Mike for the info regarding the output voltage and your sonic assessment of the KR 242.
This makes me almost want to order the KR 242 untested because my GG has only 180 millivolt...
On which setting you have the KR 242 ? PX25/300b or 45/101d/PX4 ?
But the coward that I am, I will wait for Keds 242 to test them in my GG first![]()
Since my Big 7 is in Poland now for upgrades should I have him lower it a bit?
I'll be sending my GG back to Poland in a couple of days to get rid of the distortions I've been having since the beginning and which could not be fixed in a first attempt at Lampi's.
Since my GG needs to go back anyway, I would like to upgrade all that is worth upgrading. Change to R2R discrete ladder dac is planned which will hopefully sort out my distortion problem.
As for the other options, are the two superclocks for usb only or is this worthwhile when using bnc input too?
What's it with the grounding post?......
I am not using dsd yet for a lack of a potent computer so not sure whether it makes sense to upgrade to dsd 512 with a separate dsd engine.
I had also done a DIY grounding post, but the one Lukasz installed is much nicer, as well as I know it's actually grounded optimally. my DIY was a 'hope it works' job.
I would DEFINITELY get the DSD512 option. Its the best DSD at any native rate playback.I'll be sending my GG back to Poland in a couple of days to get rid of the distortions I've been having since the beginning and which could not be fixed in a first attempt at Lampi's.
I solved my grounding issue with some diy.
Just our of curiosity, how do you guys stream DSD512 to the GG? I do have a dual streamer setup, but I have always used JPlay in the past. And if I am not mistaken, it is not possible to stream DSD512 with JPlay (only DSD128 or 256). Which program could I use for a dual streamer setup to feed the GG DSD512?
yes; currently I'm streaming 512dsd into the 512dsd GG dac from my wonderful 'on trial' SGM server with HQ Player. and when I use that dac I am up-sampling all dsd and pcm to 512 with HQ Player.
my 'other' dac, a CAPSv4 with Lampi upgrades does use JPlay and it's limited to Quad (256) dsd. I've not used it in 4 weeks and not yet tried it with the upgraded GG.
Mike,
Did you have a chance to try HQ Player (with the same settings as SGM) on your CAPS server ?
I wonder, how big the difference is. BTW - if you end up keeping your server, I strongly recommend to upgrade your USB card to the new Jcat Femto.
Mike,
I've spoken to my son about adding HQ Player and Roon to my CAPSv4 server to see what difference it is compared to the SGM. that will happen when I can nail him down. as long as the snow is flying he's skiing with all his spare time......I might buy another SSD to load the new software on so we don't corrupt all the JPlay settings and just switch the drives. could happen this coming weekend.
Hi Mike, thanks for your reply. That CAPSv4, is it just a single machine or a dual pc setup?
