Congratulations on getting that ever elusive "3D" sound stage we all want, it is a tough nut to crack. Can I ask - did you have to change your speaker position much +/- the tube traps? I often find a subtle adjustment to my speakers to be beneficial for tuning. Although not so much with my 30.1's - you can pretty much plonk them anywhere and they will sound pretty decent. Unfussy. Easy to get to sound good, really hard to get to sound great.
Andrew, I always had my speakers at more or less the same position, about 6.5 feet from the back wall (or front wall, if you want to call it that). I tried playing around with positioning at diverse stages of room treatment, and once, before I had the window plugs but everything else, moving the speakers one foot forward greatly increased energizing the room and increased depth even more, at the expense of bass output. Yet with the window plugs installed, the standard position once more turned out to be the best. I also played a bit with the spacing apart of the speakers, but also this was not influenced to a large extent by the room treatment.
