Technical correction from acoustics geek...
There are two polarities here....
If you place the subs with same electrical polarity in opposite polarities of the room mode then you will drive it destructively. This is the best online resource that explains it: http://forum.blu-ray.com/showthread.php?t=48286. Also explained well in the Toole book.
I think what you did is different, which is what Klaus refers to as "Single Source-to-Sink" (though have not read that AES paper).
The above assuming both subs are run with no electrical delay. The Welti simulations are based on all subs fed same signal, no delay, same polarity.
With electrical delay (e.g. delay rear xx ms) then you are changing how the subs are driving the standing wave. Different delays will cause different effects. You can use this to your advantage along with individual sub level adjustments to "move" the peaks and dips in the room modes where you want them.
Some simulations: two subs on front wall (dots in middle of room are seats, this is a HT). You can clearly see the 20Hz 1st axial length room mode (low SPL center of room, high walls front and back)
four subs, two on front wall, two on rears (rears delayed 2ms and run -3dB relative to fronts)
One interesting thing about multi-subs is the debatable importance of time alignment. People like Geddes are purposely advocating NOT aligning the subs in order to control the room modes. The Welti methods also have no delay adjustments for individual sub channels relative to any listening position.
You have bad water in Texas so it screws up everything including your audio equipment....That's not what I measure. To drive 1,0,0 destructively, the subs need to be in opposite polarity. When I measure and they are in the same electrical polarity the 1st gets much bigger. If they are in opposite electrical polarity, the 1st goes away. I read that bluray forum post before and I don't think that's accurate info.
I will post a REW plot later showing this.
That too. And you kept defending the guy who did your wiring despite my feedback to the contrary:No. I think the polarity is reversed on my front subs because I get cheap electricity.![]()
I'm not sure what is going on in your setup but reference Toole pg. 221 diagram (b). "two subwoofers, one on each side, radiating identical signals, destructively drive the mode reducing the amplitude. This is "mode cancellation".
This is the behavior I get from acoustical modeling simulations.
Are the subs fed exactly same signal (no digital delay of rears)? If you are using the old F112 front and the new F112v2 rear it's possible that the amplifiers are different and one is polarity inverting and the other is not. It's more likely something in your setup than the physics being wrong.
Taking it one step further, and assuming a rectangular room, if you were to place one sub in a corner and an out-of-phase sub in the diagonally opposite corner (ceiling mount), you could in theory kill multiple resonances.
I used REW and the multisub program by andyc56 on AVS (hope that's not a problem, if so I'll delete this and find my link to his site later) ti dial things in, then did lots of measurements and playing with sub phase and Dirac Live filters. Decently flat and with room gain down 3 dB around 7 Hz or so, though I have more fiddling to do, just no time!
"An effective method to equalize low frequencies
in rectangular rooms has been simulated
and implemented in these three rooms. The system
uses two loudspeakers in the front wall of the room
to create a traveling plane wave and an extra two
low frequency loudspeakers in the back wall delayed
and in opposite phase to remove the reflection of
that wall. "
Low frequency sound field enhancement
system for rectangular rooms using multiple
Adrian Celestinos and Sofus Birkedal Nielsen
You can see what I'm talking about in section 3.2. "Removing the Reflection from the Back
Wall"
This deals with the method I'm using to destroy modal ringing by running a rear sub in "antiphase."
In the paper's discussion:
"By first creating a plane
wave in only one direction of the room which implies
exiting only the axial modes of that direction
and secondly canceling that plane wave using loudspeakers
delayed at the end wall in opposite phase
with the traveling sound, optimal equalization can
be obtained."
That's a valid cancellation technique, but different to the one you referred to in your first post. Welti is not talking about cancelling plane waves.
Just trying to make sure everyone is referring to the same cancellation technique.
Bear with me, I'm learning out loud.![]()
In Table 3 of Low-Frequency Optimization Using Multiple Subwoofers, Welti and Devantier specify that for each subwoofer channel, individual delays of 0, 5 and 10 ms are evaluated in the search grid.
But in the final analysis the one they recommend were playing same signal to each subwoofer, right?
There are two papers by Welti and I think you are talking about the second one, "In-Room Low Frequency Optimization," Todd Welti, Allan Devantier, 115th Convention, Audio Eng. Soc. Preprint 5942" and Nyal is referring to the first, "“How Many Subwoofers Are Enough,” Todd Welti, 112th Convention, Audio Eng. Soc. Preprint 5602."It is a mono source signal, but after it is split into multiple paths, there is one adjustable PEQ, one adjustable delay, and one adjustable gain per channel. These are adjusted to minimize the Mean Spatial Variance of the combined sub outputs.
Table 3:
Gain: 0, -6, -12 dB
Delay: 0, 5, 10 ms
Filter Q: 1, 4, 16
Filter attenuation: 0, -12 dB
I'd have to go back and re-read more completely to see how they select the PEQ center frequency.
I cover the technique for the one you mention with a number of real measurements in my article here: http://www.madronadigital.com/Library/Computer Optimization of Acoustics.html
