Not sour grapes because I said it before, when you asked Amir to take a look at the neolith. I said never heard a panel sound good the same panels which I later heard in a proper room
Yes, you absolutely wrote that before!
Peter one doesn't only listen to tonal balance but also imaging and sound stage changes massively with toe in
Thanks bonzo. I have a good friend with Martin Logans and we noticed some interesting things about the sweet spot and tonal balance when I was last there. I'll keep this in mind for my next visit. I appreciate it.
Amir was there, we were not there, and I fully respect and uphold Amir's impressions.
I do not want to think about how bad the vibrations from the frame surrounding the panel would be with the traditional ML surround made of wood and plastic (and maybe aluminum?). I would have hoped the phenolic resin structure would be extremely rigid and solid. I will perform the same test the next time I am with Neoliths.
The rear wave of panels usually gets compromised big time at a show because of the room. They have either a glass window or a hastily put up cloth treatment behind them, instead of the flat wall that's recommended. What's a panel without the rear wave?
The bass is usually lost in a hifi show room
Panels usually used during a show have just been built in time for the big show, and as they are not burnt in, sound bright
The sweet spot is tough to locate and occupy at a show, and a panel is all about the sweet spot.
Takes months to get a panel toe in right, and it usually sounds crap till then.
You will really struggle to get a sense of space, soundstage, and imaging which panels do well in a hifi show room
My pleasure Peter. I was hoping you guys could tell me who made the turntable.Amir, thanks for the report and I look forward to your other CES reports. Perhaps MF was there to hear that turntable and the SAT arm which he liked so much in his system. Amir, do you know what that turntable is? I've never seen it before.
I can't unfortunately because there was hardly any bass in MF's albums and all I heard on top of that was Patricia Barber which also had little to no bass.Could you also speak a little to the panel integration with the woofer? In my limited experience with Martin Logan speakers, this seems to be a critical aspect to their sound.
Well, the rear wave is highly compromised by the panel shape. It sounds like a horribly muffled loudspeaker behind it. That sound then comes back reflecting at you with a delay. The brain usually ignores these secondary events as being redundant but only if they are similar. The back wave of the ML is not similar. So if I were anyone using them, I would absorb the heck out of the back reflection. But then again that may take away some of their dipole sound, I don't knowThe rear wave of panels usually gets compromised big time at a show because of the room.
You should consider my views as someone skeptical going to listen to themAmir , thanks for the in depth feedback . Lovely read and great pics . The Neoliths sounded good to me at last years Munich show ,with much humbler gear from Moon Audio . It was a fresh , out the box panel . No where near burnt in , but there was no denying their potential . Would luv to hear in a more controlled environment .
Yes I follow ack's post, as he is a classical, spectral, and Logan lover. I should check his system once, will learn a few things.
To what exactly do you ascribe the fundamentals of Martin Logan's appalling sonic performance then sbo6 ?
Why did you purchase them in the first place if they are so shoddy?
What transducers have you replaced your previous mistake with ?
Do you know your own mind ???
