If you want to reproduce the actual recording event, or just the same emotion of being there live on some recordings, it is not impossible!
Have a satisfied mind in the end!
https://www.youtube.com/watch?v=sO4PtdDp5-0&spfreload=10
Perfection is impossible, but you can get close.
http://www.performancerecordings.com/capturing-music.html
If you go beyond a stereo recording-mastering and stereo speaker setup, you can get closer yes.
There is a reason why multiple channel and front speaker solutions have been recommended over stereo in the past and/with more complex mic arrangement-recording solutions, although these never did get much of a foothold commercially (SACD I guess sort of on that path with some of their best front multichannel releases although mic-recording arrangement solution still a consideration IMO).
Worth mentioning though these recent posts have been around objective and definable aspects to accurate-neutral-transparent-natural-etc; I agree with a lot you say but worth pointing out emotion and connection to the performance/recording does not fall into that criteria, although it is critical as part of the drive to reach best satisfaction-enjoyment for audiophiles (and I would say for many of us in this hobby including myself).
Edit;
Just to add.
Bear in mind these recent posts are coming from a specific context and that is the objectivist perspective of accurate-neutral-natural and view what we listen to should be as close to the original performance, so this post is just an extension of what has been said so far and my point what we listen to is a compromised illusion that has been tweaked anyway.
This was only a small part of the discussion we have had and not the main crux (which was focusing on the difficulty of perceived neutrality in a system due to the complexity of an overall system including speakers and that measurements can be excellent but a component can be perceived as being warm-rich and that does not fit into the description of neutral-accurate for all), albeit it is important in the concept of natural and matching the original performance, this is more complex than simple absolutes IMO anyway.
Cheers
Orb
