Well stated. I think that statement applies universally to both sides of this discussion.
So where to from here?
Any consensus yet?
I can conclusively say that is wrong.I think the only thing that we can all agree on is that nothing has been proven. Conclusively or otherwise![]()
Of course we do Tim. The results of the testing I did had probability of chance being essentially zero. With respect to my hearing abilities running that test, with my equipment, that is statistical significance.No, of course not. We don't even have a statistically significant sample of the test that started this thread,
Amir, I think a summation of what you think was proven, and why, would be goodI can conclusively say that is wrong.![]()
Do you mean something else with that statement?
Are we talking about the original test? The one in which you were the only subject? How many trials did you run? Maybe I'm confused.
Tim
Simple answer to your simple question, Dude: nothing has been resolved. I think most of us can agree that a difference was heard by a handful of people. . .
snip....
The question now becomes why? I understand that that the answer to that question will be discussed in the Meridian paper being presented to next month's Audio Engineering Society convention.
John Atkinson
Editor, Stereophile
I reported on this many pages before. I passed one out of his three tests:
Speaking of Archimago, he had put forward his own challenge of 16 vs 24 bit a while ago (keeping the sampling rate constant). I had downloaded his files but up to now, had forgotten to take a listen. This post prompted me to do that. On two of the clips I had no luck finding the difference in the couple of minutes I devoted to them. On the third one though, I managed to find the right segment quickly and tell them apart:
foo_abx 1.3.4 report
foobar2000 v1.3.2
2014/08/02 13:52:46
File A: C:\Users\Amir\Music\Archimago\24-bit Audio Test (Hi-Res 24-96, FLAC, 2014)\01 - Sample A - Bozza - La Voie Triomphale.flac
File B: C:\Users\Amir\Music\Archimago\24-bit Audio Test (Hi-Res 24-96, FLAC, 2014)\02 - Sample B - Bozza - La Voie Triomphale.flac
13:52:46 : Test started.
13:54:02 : 01/01 50.0%
13:54:11 : 01/02 75.0%
13:54:57 : 02/03 50.0%
13:55:08 : 03/04 31.3%
13:55:15 : 04/05 18.8%
13:55:24 : 05/06 10.9%
13:55:32 : 06/07 6.3%
13:55:38 : 07/08 3.5%
13:55:48 : 08/09 2.0%
13:56:02 : 09/10 1.1%
13:56:08 : 10/11 0.6%
13:56:28 : 11/12 0.3%
13:56:37 : 12/13 0.2%
13:56:49 : 13/14 0.1%
13:56:58 : 14/15 0.0%
13:57:05 : Test finished.
Total: 14/15 (0.0%)
Amir, I'm downloading the files right now and will give it a try. Do you have any idea about the spl you were monitoring at ? IME this is crucial for audibility of low level noise. Everyone has a hearing thresholdI passed one out of his three tests
The problem though is that in reality the blog is NOT doing 16bit vs 24bit, they are doing native (although ideally should be in-depth analysis of the PCM files for validation before testing) 24bit vs decimated.
If they were actually doing this from the age old debate of 16bit vs 24bit then you would need to record twice at different native bit depths (and rates if that is also part of the context); once for 16bit and then once for 24bit.
The result would probably show that in reality 16bit is not enough (technically been shown ideally need roughly 20bits "normally" and 32bits if wanting to ensure-guarantee transparency transcoding of DSD -> PCM) when one also considers the studio and the process-chains involved.
So the debate needs to change the age old argument more towards; native 24bit and sampling rate vs downsampled/decimated/upsampled/transcoded (PCM<--->DSD).
It may seem I am being a bit pedantic but this is an important differentiation from what many still think of from the past POV on 16bit vs 24bit, that then helps define how one approaches the scope-focus-context.
Thanks
Orb
