I have just ordered 3x STILLPOINTS - ULTRA 5 to put under my Clearaudio Innovation.Anyone else using this combination.My only worry is I become addicted and put them under everything including my listen chair!
Stump
Stump
I tried them under a SME 30/12 and the experiment lasted 5 minutes. Turned the sound to a thick muddy mess.
That's what Christian did!
Not surprised. Hard to mess with an already exquisitely designed and implemented suspended design. The most I would ever do with a suspended table of that caliber is provide it with a very solid and stable platform that transmits as little as possible from the floor. Oh, you did that.
Actually I did not use them under the Clearaudio as I use the Table Stable isolation platform. Short of using that, the Stillpoint Ultra 5's are a good choice or a passive device like Minus-K or Vibraplane.
Christian, Have you considered trying to place your superb TechDas AF1 on the Table Stable platform or do you think with the air suspension, the TechDas would not benefit from further isolation? I still wonder if the active technology in the Herzan devices will find their way into a mass loaded non-suspended turntable design. Could be quite expensive, but we are already there with SOTA designs like the TechDas and some others.
That's what I thought until I tried a preloaded Vibraplane under my SME 30/12 for a total mass of 400 lbs. The SME has a great suspension, but I found that the table can indeed benefit from additional isolation like what I tried or like the HRS platform under Frank's table. I think the SME suspension in large part is meant to address vibrations at certain frequencies from the motor. By adding something like what Frank and I have done, you further isolate it from floor/ground/structure borne lower frequency vibrations. But under that, yes, a very solid, rigid and stable rack is essential.
Syntax (on Audiogon) discovered the same thing about isolation with his well-designed suspended Basis turntable when he placed it on a Vibraplane and rigid rack system.
Cheers John
I just put the Ultra 5 under the Clearaudio Innovation but at the same time my replacement cart has arrived.They look great and in theory helpful for vibration.As I don't have super sonic hearing and memory like some I don't remember the old sound to compare with the new.They sounded Great Both Times.Ill give the sound a while to normalize my brain then if I remove the Ultra 5 and give it a spin I will have a better chance to notice a downgrade in sound.
Cheers Stump
Cheers John
Cheers Stump
Wall mount for instance, furthermore I've "mechanically grounded" my suspender directly with 3 bolted BDR cones, on a light and very rigid platform w/wall mount. Note: not all wall mounts are created equal ... I've witnessed many which acted like a spring.
I've had limited success with differing type still point types under turntables. The only times I found these devices to "work" under certain turntables (esp non suspension decks) is when the shelf it sits upon - is a compromised affair.
tb1
