I listened to some of Tusk with headphones the other day. Did it have a rather strange mix? Some sort of attempt at hyper-stereo with stark panning of instruments left and right? And strange mixtures of dry and reverb'ed?
Don-I hate to be dense, but I'm not sure I understand your question when you say "Compared to what?" The version of Nightfly that I commented on is vinyl. I stand by my comment that Nightfly is a good sounding LP that maintains its digital roots on vinyl. What any cassette version of Nightfly sounds like, I would have no idea. Ditto for the digital master file.
Also see here:
http://granatino.com/sdresource/18crime.htm
"When digital first came in, there were many formats being kicked around," McKaie tells ICE. "One of them was these oversized Scotch reels, digitally encoded analogs. That's what Steely Dan chose. Realizing their analog masters were deteriorating, they went in and remastered all the albums on these oversized, heavy-duty reels. When it came time to do the CDs, they said 'Use those,' so on the first go-around, they (MCA employees) did. Unfortunately, the oversized reels was one of the formats that lost. So when they did the second go-around of CDs, the studio (engineers) didn't have access to those machines: there are only a couple of places that do. So, having the original analog tapes, they probably just did what they thought was right and used those. Unfortunately, those original analogs don't sound as good as the digital transfers that the group did on the oversized analogs don't sound as good as the digital transfers that the group did on the oversized Scotch reels, because Steely Dan had really worked on them to get them right."
"Hence, the second CDs don't sound as good as the first, albeit they don't sound bad, and I've never had any complaints.
Very interesting...
But doesn't something strike you as odd? If you're re-issuing a CD, why go through the rigmarole of messing about with tapes etc. when you've already got the bit-identical digital version in your hands in the form of the original CD? Why not just rip it? It seems they were still very much in the analogue mindset.
'Modulation', Tim got the term wright! ...That's the key ward indeed. ...It can only go uphill from down here. :b
* "High-quality discussions" from Google's search archives. ...I luv it!
Many still are.
Tim
Clearly not... however 5 years later (in reality 5 microseconds), the analogue tape will have deteriorated while the digital version won't. And the analogue playback may be on a $100,000 machine perfectly aligned, cleaned, de-magnetised and set up by experts. I will get an almost perfect copy of the tape and the machine, to play on my own system.And that is not a bad place to be. Who thinks that you can take an analog master tape and flip it to digital and think that somehow the digital version of an analog recording will be better sounding?
Not according to Bernie Grundman mastering...
Why what does he say about it?
"every time an audio digital file is copied, it loses ambience" Paul Grundman
That, of course, would indicate that there was a device malfunction, if actually true for direct digital copies. If a gain is applied, maybe. If processing is applied, maybe. If it's a direct bit for bit copy, no, never. Any such evidence shows that you didn't have a bit for bit copy, and there is something broken.
