Put 5.7.3 in my DP earlier today, no sonic difference.
5.7.1
I need to listen more
Thanks. Then 5.7.3 is different from the 5.7.2beta I mention above. In my system I found 5.7.1 a bit bright and 5.7.2b a little darker and very organic. 5.7.3 is more like 5.7.1 then. Will be exiting to hear what 6.0 does with the sound.
This is why Devialet amplifiers are part of the reference toolkit of nearly every major speaker-manufacturer. The Devialet being absolutely neutral in terms of sound reproduction, what you get to hear is how the speaker REALLY sounds (...)
Anyway I wish to concur with ogs's comments and I too found 5.7.3 a bit bright and harsh sounding compared to 5.7.2b.
I'm a new comer to this forum and have been following this thread with interest, i'm looking to trade in my Naim NDX/Supernait/Hi Cap for the Devialet depending on how well a dealer demo goes.
The thing i'm most concerned about is the usability, so far you can only use with iTunes which is not great and I noticed you can stream internet radio using iTunes from a mac but, but what about streaming music directly from an ipad? Can you stream internet radio from an ipad with out resorting to use iTunes with a mac/pc?
I'm guessing Sonos is the only alternative for streaming internet radio?
Do you mean 5.7.1? Is this maybe a typo? I have not listened to 5.7.3. My comment concerns the 5.7.1 and 5.7.2beta. And I would not describe the difference anywhere near harsh.
I am not sure if I understand right what you wonna say. Devialet says that a running iTunes is and will still be needed for the Devialet.Basically, whatever's feeding your NDX can be used to feed the Ethernet port of the Devialet 110, 170 or 240. You might need to use PlugPlayer or a similar app to control your media server (and it might be wise to wait for the first reviews to see just how the integration of the Ethernet port panned out - I suspect it will be OK).
Don't like 6.0? it's not a seasoning we are talking about...
I just updated though and I have to say that the AIR 2.0 software for PC is extremely sketchy so far, it doesn't work very well at all.
oh man i feel silly now![]()
