Ok, there were a few. For me measurements should report numbers and units, but the conditions of the measurements have to be clearly specified. Unhappily at previous posts I can only see very few quantitative values. But one of them is -80 dB for all distortion in amplifiers as threshold for being not audible. At what power and with what signal should we measure it?I have shown an awful lot over these pages! If there's something you don't follow, tell me what parts you don't understand and I'll try again.
--Ethan
What I find absurd is saying only "You're wrong," without bothering to type even one sentence explaining why I'm wrong or what is right.
--Ethan
Here's a simplistic way to assign a percentage value: We can ignore electronic gear and cabling etc because anything decent will be flat within 1 dB over the audible range. Good loudspeakers are flat within 10 dB if not less. But most rooms vary by at least 30 dB, especially in the bass range.
A 20 dB difference is a 10:1 ratio. So loudspeakers have more affect than electronics by 90/10, and the room is more important than speakers by 90/10. Therefore:
Room = 90 percent
Speakers = 9 percent
Everything else = 1 percent.
--Ethan
OK. I will try to explain.Real music as a opposed to just test tones. Is that the best argument you can come up with?
I don't measure I'm subject to ridicule. I measure and I am subject to ridicule. It is my mistake for taking you guys seriously. I use this device which comes with test cd and is used at live concerts by professionals to check among other things frequency response. It cost around between 300 to 500 dollars so I could afford it. It is also easy for the lay person to use.
Steve's Lamm ML3's can actually put lipstick on a pig. to say that it's contribution is less than 1% to the audio reproduction is an absurd statement.
So as to keep this thread moving on with the OT in mind instead of devolving into a flame fest, and since Randall appears to be following this thread, I thought I'd ask Randall for his comments on Jeff's article. Randall, what say you?
That's a huge problem unless you're saying that Steve's Lamms have some really precise and powerful EQ built into them, because even if it isn't a pig, even if it Ingrid Bergman, it's still going to paint it with the same lipstick.
P
there are amplifiers, and there are other amplifiers, and then there are the ML3's. they are likely not strictly neutral, and who knows how they measure. but pretty much anyone who has heard them has fallen in love with them.
any reasonably efficient speaker system powered by the ML3's will make wonderful music happen. my point was that any decent speakers in almost any room would sound special with that amp.
it's an experiential thing; you'd actually need to listen to the ML3's to understand.![]()
I'd love to hear them, but I'm afraid it wouldn't help me, or anyone, understand that. I'll take it as a penchant for overstatement and let it slide, I suppose.
P
Room = 90 percent
--Ethan
Randall, great post.
Mike, having been extemely fortunate enough to have been invited over on numerous occasions to Steve's, I concur that his system is indeed extraordinary. Having stated that, there is no question that Steve has chosen those amps because he likes the flavor they contribute to the sound in his room, and he has posted the same on numerous occasions. That those amps impart the same flavor on all source material is not legitimately in dispute. PP is absolutely correct.
Mike, go back and read Ethan's original statement. It is a qualified one.i included both amps since there are speakers that could be a bit too tough a load for my Stereo darTZeel....whereas the 450 watt Monoblocks can handle anything.
i think either of these amps would make a much larger than 1% effect in a positive way on a system.
Good, perhaps, but not great. Neither objectively (as measured) nor subjectively (you have to hear the difference to appreciate it). Not sure if that's what you meant.I agree that Ethan has overstated the importance of the room. Not that a really bad room can't ruin a great system, it can, but given a reasonably normal living space with rugs and some big soft furniture and a pretty normal mixture of hard stuff and soft stuff, a good system will sound good...
well; until you listen how can you know you would not love them? you need to listen to amps like this. like sitting in a museum looking at a Van Gogh (that cannot be measured either).
i admit i have a penchant for really great sounding amplifiers.
i don't own the ML3's as i agree with Ron that they do add some color (and my wife would kill me). but it's the most glorious color.
