I agree with Gary. It wasn't close with the provisos indicated.
Interesting. It could be that a different cartridge would favor the Graham and not the Vertere who knows. The two arm pods could sound different as well.
In an endeavor in which some people claim that moving the cables change the sound of a system. a comparison between two arms with two different cartridges can not be construed as a valid.
Frantz,
It depends on what you want to consider a valid comparison in the spirit of this thread. If you trust in the experience, explanations and good will of the people who report, and accept the limitations that can be due to these effects you refer the comparison can be a some value to you. Gary clearly addressed the different cartridge issue, people can not ignore it, but also explained why in his opinion, it would not compromise his and other people opinions. Surely you are free to not agree and make some humor with cable positioning.
I think some people are expecting too much from this thread.
These are the first pictures ever released of the new $35,000 Vertere Reference Tonearm. WBF gets a world's first. Here it is mounted on the fabulous TechDAS Air Force One.
I don't know if it's the first, neither does the designer as we have not seen every tonearm in history, but it's got a couple of unique features. First, it has different length vertically and horizontally, and hence effective mass in the horizontal plane is different from the effective mass vertically. Secondly, it doesn't use ball bearings/ball-races in the major pivot. It uses a leaf bearing.
Finally, the wooden insert at the armboard mounting plate is an interesting choice. This would effect the sound pretty dramatically, I would think.
I'm just curious because people discuss the sonic character between different materials to which the arm is mounted. This was an early subject with the NVS Direct Drive table a while back. It was first wood, then what kind of wood and then they ultimately decided to go with a metal which I think is aluminum when it was redesigned to accept 12" arms. This material also moves with changes in temperature and humidity effecting the mounting distance of the arm to the spindle. Though admittedly, this is small. This is also where energy is drained from the arm system into the plinth. Different materials handle vibrations differently. Some armboards or (even arm bases) are massive hunks of metal (Durand Telos, SME 30/12, Micro Seiki, TW Acustics) others are thin or thick acrylic and still others are soft wood, hard wood etc. I'm sure it all makes a difference.
So TBone, what table and arm do you have? If you feel proud enough to tell us how good it is it would be helpful if you would list your gear under your profile.
Eventually, I'm lazy, it's no secret tho, long listed on AA, and trust me ... I doubt my actual description of my gear would be all that helpful to most, but you never know ...
tb1
Okay, how about a link to your profile on AA?
My last thought on this arm....
Personally, I would buy any number of very respectable arms for $5-$10K and with the remaining $25K or more, I would buy a lot of awfully good vinyl. Just IMHO.![]()
Dave,
People who buy this arm probably already have the $25K lot of awful good vinyl. And want to spend time listening to it, not buying ...
