Isolation is needed to prevent leakage, particularly in the bass region where energy can be coupled through the structure. My media room does a pretty good job with floating walls and ceiling (concrete floor) and 6"+ of mineral wool in the walls.
I think what Ethan is saying is that you want bass to "leak" out of the room. Concrete floors or walls are usually not the way to go.
Your comments are only true if you care more about whether your neighbors can hear your music more than the quality of the music you are hearing in the room. You want sound to escape the room, just like Ethan said.I was addressing Nightlord's comment about leakage getting him/her/it into trouble with the neighbors due to LF transmission.
I am not sure Ethan said exactly that, but perfectly reflective walls (zero transmission or absorption) would provide isolation but increase the magnitude of in-room modes (and SBIR, natch). I am not sure that is good or bad (I lean towards "good" for isolation is usually a design criteria) but in practice I am not sure there is a large difference in the magnitude of a peak or null whether the walls are concrete or plaster. Note reducing the magnitude in-room by using "flexy" walls means energy is escaping from the room, again not necessarily a good thing. It may be worth highlighting that treating a room acoustically is not usually the same as providing isolation; they are usually independent goals with different techniques used to meet them.
I need to look up SBIR; I thought it applied to both constructive (peaks) and destructive (nulls) interference.
Comb filter effects are quite annoying and one reason I prefer a more "dead" (highly-treated) room than a "live" (reflective) room.
I do use a microphone (Earthworks measurement microphone) and SW (RplusD) to help characterize a room's sound.
Onwards - Don
Anyone that thinks they can identify the exact frequency of a null "by ear" is smokin' something. It's not possible.
I do not believe isolation and in-room treatment to be mutually exclusive; it is most certainly a goal of every recording studio I have had the privilege to work (on either side of the glass), and both are goals of virtually all sound rooms I have helped design. In-house or commercial.
It might be possible to design walls that isolate and also absorb bass. But the usual method of using mass to increase isolation does indeed make the peaks and nulls inside the room worse. High-end studios therefore have massive walls, and they also have even more bass trapping than usual to counter the stronger reflections.
--Ethan
Actually your straightforward double drywall with green glue in the middle does a spectacular job of damping LF and providing isolation.
I can imagine that works, and I'd love to see real data. But "plain" mass still vibrates at some low frequency, and that passes sound through to the other side.
--Ethan
It would be more interesting with graphs done for those components individually. I can get green glue over here, and possibly I could talk someone into shipping clips - but we don't have your size hat-channels over here and that's not something I'd pay for transatlantic shipping on. So I'd be more interested in how much is the glue and how much is the 'movable wall'.
And as always... The interesting bit below 20 is off the chart...![]()
Here's another with the back two subs turned off (that's why the big dip appears, since the back 2 are helping fill in the SBIR related dip that comes off the back wall) around 55Hz and some EQ applied. Was just playing around![]()
Nyal,
I can guess your listening position is around 5 feet from the back of the room. Can I ask how many subs do you have and where do you locate them?
BTW, I am inserting a link about SBIR Speaker Boundary Interference Response something many people are not aware of:
http://www.acousticfrontiers.com/Speaker-Boundary-Interference.html
