An enjoyable and unique rendition of Brahm's 'German Requiem' spoiled only by what I take to be noise modulation from the ADC. Its particularly evident on vocal consonants (the choir here is 16 strong), sounding like a softer version of sibilance, a kind of rasping or lisping. The other effect it has is flattening of the soundstage depth, preventing really listening in to the recording by imposing a wall of cotton wool over the subtle ambience details. Nevertheless musically very pleasurable, especially for anyone already familiar with the traditional version of this Requiem.
http://www.amazon.com/Brahms-Ein-Deutsches-Requiem-Johannes/dp/B000URDDX4/
Hey Opus...did you happen to see my post on this thread about DG and their ADC equipment for their studios? I believe this was the list of equipment likely used for the recording of Bach you listed by Helene Grimaud. Let us know what you think of it...and how it relates to the sound you heard on that particular recording! Thanks!
Why not just peak the analog output with your filter (add a peaking stage)?
Its something I tried building a while ago and never got to like the resulting sound. Added to that it needed to be fairly high Q to get a flat response, and tuned around 30kHz. I wonder if the high-ish Q was responsible for my not liking how it sounded? I rather like the multiple DAC solution because its flexible in getting the FR as flat as turns out to be needed - with the high Q peaking stage the FR turns out to be rather sensitive to the precise value of an inductor. The extra DACs help to smooth out bit weight mis-matches in the main DACs too which I reckon will improve low-level linearity.
This one is vintage Richter but only the Rak Preludes sound good - on the second half of the disc, the Etudes Tableaux are washed out rather, lacking dynamics. Looking on the notes I find that the Etudes are 'DDD' from 1988 but the rest are from 1971 and presumably ADD. Score 1 for analogThe preludes here make the disc worth its weight in gold for me, pure magic from the master himself. I want this one on repeat all day long
http://www.amazon.com/Rachmaninov-Preludes-Etudes-Tableaux-Sviatoslav-Richter/dp/B003CP1SRE/
<edit> I wrote the above while only having listened as far as the first prelude. I'll temper my recommendation now in noting that there do seem to be disconcerting variations in level as if some overzealous recording engineer is riding the gain control during the analog recordings.
IME, after certain level of refinement to my system. the biggest improvement came by listening in the correct polarity. In the correct polarity, you will get better soundstage, tonality and timing. It actually affect all frequency range. In stringed instruments, you will hear more of the strings interaction. And the resonance created by strings, piano and brass is easily heard. The effect of the rise and fall massed strings will be dramatic. In the wrong polarity the rising of massed strings will not create the loading effect on the room. You will only hear a louder but flat or hollow sound but will not feel it as you should. In certain very forcefull recordings, as it falls, you will literally feel somewhat like feeling the floor giving way. For vocals, you will hear more of the throat and chest rather than just the mouth. This probably is what you hear that makes the opera so moving. For bass, you will hear it radiate outwards and decay naturally. It will also be fuller. In the wrong polarity the bass will be pinched and often mistaken for tighter bass. For high hats, you will hear the rumble as it settles. In the wrong polarity it will sound diffuse and indefinite. A surprisingly good genre to determine polarity is electronic music as artificial sound effects tend to have good directionality. Winds and atmospheric sounds are weird in the wrong polarity. A good example is brendan perry's this boy from the album ark. In correct polarity (inverted), it will load the room from wall to wall in a solid chunk and the bass will radiate out endlessly. As a guide, blue note, columbia and atlantic are positive or normal and DG, emi and sony are inverted.
Hi Opus, maybe you could just build a switch on the dac to flip the polarity or just switch the wires at both speakers as not all recordings are in the same polarity. The key is actually the speaker's drivers polarity. If it is not in the same polarity, it's rather pointless. Oh I forgot earlier that blue note issued by emi in EU is in inverted polarity but blue note USA is normal. Another thing that you might want to experiment is to change your dac grounding wires to silver. Controversial to most, I know, but it won't cost you too much so you might want to give it a go.
