I thought this was established back at the beginning of this thread (for everyone except micro)?
Indeed Soundminded post however, describes a simple test that put things in better perspective ..
Micro takes more measurements than most of us here.
Irony or paradox or simply pulling our legs .. That he does and experiment more than most of us here ... Not much in the way of tweaks but carefully conducted almost scientific experiments ...
Indeed this is correct! If this was a consensus opinion, then we could all make some progress in trying to work together to get some measurements that better correlate to what we hear. Unfortunately this may be the ramblings of an idealist as audio is really not of that much importance in the scheme of things to warrant the necessary research time & money required to begin to address these difficult issues. So, I guess, the audio world will continue to be polarised along the same ol' lines.I agree with that. This has been my contention for many years. It isn't that what we hear can't be measured, if it exists at all then we are able to find ways to measure it. The current set of measurements is insufficient, we need to devise a different set of measurements. The current set does not tell much or to be kind enough to make valid choices.
I went to a large audio show in the UK yesterday, and I cannot tell you how appalling most of the 'High End' stuff was to listen to. I'm no audiophile, but I can spot systems that are just 'not right', and most of them weren't, despite huge horns, massive turntables (with microscopically thin belts..?), tube amplifiers, cables as thick as your arm and 'audiophile music' that seemed designed to reveal as little about the system's true capabilities as possible. The only decent sounds were from large manufacturers like Tannoy, or purveyors of active systems. There's an irony in that while audiophiles may have been persuaded that tubes and vinyl are the ultimate audio source, the speaker manufacturers have been taken in by it too! So people are trying to sell their product with one arm tied behind their back. A few sensible speaker people hid their sound sources from view...
The impression I gained was that the 'High End' audio industry has become so 'high' on the idea that measurements don't matter, that it has lost sight completely of the basics. Subjectivists are messing about with cable supports and mains conditioners while their systems truly, truly suck. In a way I found it quite exhilarating: my own frugal system is so far ahead of $50,000 systems in every respect that it is almost a joke. You may say that an audio show is far from ideal for assessing the subtleties of 'sound stage', 'imaging' and 'presence', but first you have to get past the literally nausea-inducing defects that were all-too obvious. The more measurements-based products shone through clearly, and were cheaper (although some actives went up to over $100,00 and sounded just fine).
Yes we agree on this.
But that still doesn't take into account the biological variables.
The biological variables are the nature and limits of what can be perceived. That can't be fully measured until the physics of sound is better understood. How can you test the perception of a variable when you don't know what that variable is? The fact that people hear differently (assuming our brains don't really process sound the same way, something we just don't know for sure) doesn't change the ability to recognize and remember what something else sounded like and whether or not what we hear now sounds the same. We may not see the same but unless you're color blind we all pretty much agree what the color red is as distinct from blue and we recognize the difference between the shape of a house and a horse. Whether you prefer a red house to a blue one doesn't change your ability to perceive that there is a difference.
I guess this depends if we're talking about the open floor of a convention center, or a hotel room. A hotel room is not an ideal environment; it is more like a domestic living space than a treated listening room. You should expect some room gain. You should expect some reflections. You shouldn't expect the system to fall apart, because its designer should have expected most of his systems to play in the domestic living spaces.
This is a decent excuse for imperfect sound, a thin excuse for dramatically bad sound IMO. Put me in camp with Toole/Olive -- design speakers that have pretty even response, even off-axis and they should sound good in a decent, untreated room. Can you squeeze more out of a system through treatment? Sure. But if it sounds awful in a reasonably soft, furnished room, if it requires treatment to sound good, the design is faulty. MHO, YMMV.
Tim
People who do not appreciate the high-end will find there lot of ammunition - shows are mainly driven by marketing and have many intrinsic shortcomings. One of them is that they can present a wrong view about the high-end to those who just see the tip of the iceberg. All IMHO.
Tim
Thanks Soundminded
I would add to that that there is a constant, the physical stimuli, however I perceive blue (It could create the same sensation as red does to me in another person brain), the physical stimuli that creates the impressions remains the same. Whenever it is reproduced then ... Let's not make too much of these "biological variables". they are overplayed. Sound reproduction is a technology and it is based on science. We don't know it all but we know a lot and we can , should, try to derive ways to correlate our perceptions to the physics of it.
I am with Don and others on the need to derive better set of measurements. My experience is that many amps that measure similar in the usual category don't sound at all similar; I have laways found it odd that most of the usual measurements, even power ratings to suppose something a transducer is not: a simple resistance... A transducer is more complex, and amps behaviors under such a load seem to vary widely.
Will we see better measurements? i am not sure about that... There is a lot of money to be made in the High End Audio sector, our hobby, people in this hobby have shown an interesting propensity to spend more and more in their search for "best", the present fog about measurements and the clear shift away from High Fidelity toward "preference", about what "our ears tells us" is concussive to make even more money thus the constant increase in price of the so-called SOTA components .. Cynicism? no.... Realism
Sound reproduction is a technology and it is based on science. (...)
