I have about a 3-4' gap behind my triangulated corners. They are built with 4" of 703 on all 3 sides with Guilford of Maine fabric covering.
(...) that give you the same volume of absorbing material + whatever secret sauce they add to their traps.
Yes, it would interesting. As it is my understanding that an air gap behind an absorber, will significantly extend the low frequency effectiveness of the same absorber. More so than filling in the same amount of gap with additional absorption material.
Thanks. I have a set of swatches for this fabric. Did not realize it had special acoustic properties. I ordered some cotton canvas that I was planning to paint in the color of my walls. Sounds like a doomed strategy .....![]()
The issue I have with the 'super chunks', is they also affect high frequencies. I am seriously looking at Realtraps, because I do not want to impose any additional high frequency absorption, while aiming to tame modal frequencies.
For $2200 + shipping you can get 8 realtrap megatraps, that give you the same volume of absorbing material + whatever secret sauce they add to their traps.
A naive question - considering a rectangular room a large bass trap could be built in the back wall? Or its performance will be better if located at the front wall?
Isn't it time to end this infomercial?
It's even a bit less than that with our quantity discount.
