Natural Sound
(...) So I think detail and resolution are describing pretty much the same thing. (...)
They are related, but IMO not exactly the same thing. Resolution is the capability of isolating and showing something, the details are fine points.
I associate detail to very specific and individual events , resolution to the ability to dig in aspects such as separation of melodic lines, sound stage layering, more global aspects. IMO a system can sound detailed and have little resolution. Consider that, for example, small amounts of proper distortion can enhance detail.
Makes sense. Although timbral detail can also fall under the umbrella of resolution.
I agree with that. For example, my previous speakers accentuated the detail from the friction of the bow on string instruments, e.g., of solo violin or in a string quartet. They did so in a way that, as I am quite confident now, was due to distortion.
The friction of the bow did not sound natural? I think we need a panel of « friction » experts to check this… I’m out!
I agree.
But what question does that answer for you?
For me, answering that question doesn't tell me which recording is the more convincing or believable reproduction of the sound of that instrument.
Assuming it’s a very good recording, it tells you which system is more truthful to the real thing. It will also be more accurate with all other recordings as long as the full sonic range was covered by that recording.
I simply meant - as you mentioned in the rest of your post - that there is no method that can decide for you what is more "realistic" overall. Although perhaps with AI? :)
I was thinking about all this because I actually went to audition some speakers this morning... It was fun.
While it is impossible to summarize the sound that is heard through a simple set of criteria, I find it equally difficult to listen to recordings and ask myself whether they sound like live music or not, because they simply don't. The dealer played a Johnny Cash track and I closed my eyes and simply enjoyed listening, but I don't know what Johnny Cash really sounded like. I played that David Watkin Bach solo recording which was mentioned in a thread here, and it sounded pretty good. It did raise some questions, but the acoustics were not ideal. I am not that familiar with the track, it is played on an old instrument - it is not so easy to compare it to a reference.
During that audition, I did try to evaluate some aspect of the sound, in comparison to what I am used to listening at home: resolution, neutrality, dynamics/speed., etc.. What did I conclude from it? That I will be returning next week for another listening session!
Which speakers? What amps?
If you have ever lived with a violinist and actually compared the sounds of different bows on different violins, then you would understand that that bowing sound can be quite unnatural on many systems…not that I think Al has any idea what natural bow friction sounds like :rolleyes:
Sure I don't, Mister resident super expert. Just a few chamber concerts here and there...actually, quite a lot of them, upclose to the instruments, further away, and in between, and in very different venues. But hey, it all doesn't count because I'm deaf anyway...and you are the undisputed expert...carry on...
The distinctions you draw are listening distinctions. Do you think each of those is the consequence of intentional component design? For example can a component be designed to separate melodic lines but lack detail?
I would not say "lack detail" , but be less detailed. But yes, I think that it is designer intention. But the overall effect is a system property, including room.
Have you ever compared bows on three different violins, each worth in excess of a million dollars? Have you heard daily practice with said instruments for 4 1/2 years and recorded said instruments with professional microphones and recording gear? Remind me to pay attention to your comments about bow string friction once you have experienced some of those things…
The subject at that moment was the distinction between detail and information. You were asked to elaborate on your comment and we are still waitlist for your response.
Information and detail are very interesting words when it comes to playback. I’ve been experimenting with cables with more perceived detail (silver) and added a super tweeter.
The addition of the super tweeter is extremely subtle but I really think it’s improved the realism.
Reactions: morricab and Al M.
Hi Jeff. What is the extension of the Hartsfield’s before the super tweeter? And how do you like the silver cables?
Silver speaker cables, interconnects or both?
I have zero expertise in bow friction (and violinists…). I was just amused by the example chosen by AlM…
Reactions: morricab
Most cables with networks have cutoff frequency above 150 KHz - they do not affect frequency in the audio band.
example transparent cables have a zobel network and inductance in the plus wire the filter effect will begin earlier. ;)
MIT and HMS cable have a complex network that changes a lot in the audio sector.
When the HF distortion is removed, the audio range changes across the entire spectrum. It depends on the amplifier,how much it is his bandwidth and it tends to oscillate.FB8AMYQGE2QSNUZ.jpg
My transparent Audio ref XL complete loom of wires and power products basically expanded the scale of the sound stage for every recording overlaying it with a sameness. The wires specifically emphasized low frequencies and high frequencies for enhanced detail, but removed what I would describe now as rich tone and mass from the lower mid range upper base.
With my limited exposure at the time, I thought this was all a good thing, but then I started listening to more small and large scale classical live music. It took me a long time to realize that the wires and power products overlaid a sameness to everything and enhancing while at the same time diminishing. Over time and increased exposure, I abandoned the products for stock power cords, and more conventional wires.
Reactions: jeff1225
The 076 bullet tweeter goes out to about 16k, and I have the Tannoy super tweeter kicking in at that frequency.
My cables were all beldon, with the double shielding recommended on Jeff Day’s blog. I experimented with Kimber’s silver cables and enjoy the increased detail.
Reactions: PeterA
When the HF distortion is removed, the audio range changes across the entire spectrum. It depends on the amplifier,how much it is his bandwidth and it tends to oscillate.View attachment 162256
Again and again the same old picture from a more than 30 years old Transparent Audio low range audio cable ... Martin Colloms measured their cables in HiFI News and reported values similar to my own measurements.
MIT networks also have been measured and have poles well outside the audio band. Some high capacitance cables used with high output impedance tube preamplifier have cut off much bellow cables with networks and no one complains ... No experience with HMS, if you have data to share I will be thankful.
Fortunately most audiophiles are knowledgeable enough to believe in objective facts, not internet rumors. But yes, removing noise well outside the audio band can change the sound signature of a cable.
