Rock and Drum videos thread
These last videos sound very good. The sound is very open, airy, and does have good bass. Is the overall tonal balance faithfull to the recording? Hard to tell with a video, but perhaps this is not so important.
I have heard this system in a previous iteration and all those posted then were quite representative, some were recorded during the listening session and some after that, all consistent. Based on that, these seem representative but I haven’t heard the current iteration of this system, will do.
And yes, that iteration was a top system.
BTW, you are listening to tape now so all you and Al are saying you can hear the quality of safety masters over videos on a good system
Thanks for pointing that out.
This is obviously a “large” system - something that I could never consider for my living room, but it is always interesting to understand how it works. Does @christensenleif@msn.com have a description of his system somewhere?
I'm not sure that I would go that far. Yes, you can hear that it has to be a good system, but saying you can hear the quality of the tape specifically gets into sonic detail that the video does not necessarily provide.
Would you be able to hear on video the difference to the vinyl, for example? Not sure about that, unless the two sources were sufficiently different in basic character on those tracks. If the tape had much more bass impact, for instance, you would probably hear that on video.
You missed my point. You are hearing better quality on video because it is a high quality tape, which is better than almost all sources. The LZ3, for example is too bad to post. His vinyl also sounds great, and for those of us who use videos to evaluate both show fantastic quality. But you specifically seem to not use videos to evaluate, but kind of rank it on absolute sound, and are just choosing the best video (s). Anyway, that is also why I prefer mobile phone videos, as they help evaluate better, rather than using gimmicks which improve sound quality of the video but interfere with ability to evaluate
@hopkins
Speakers:
DIY CD horns for TAD TD-4003 incl custom cnc´d bronze adapters 600-20K driven by all out Borderpatrol DIY 300B monoblocks.....all signal iron is nanocrystalline cores from Tommy Hørning in Denmark
hipassed with Duelund cast cu passive filter...includes some esoteric platinum resistors and capacitors
DIY dual midbasshorns, ventilated rear chambers, JBL 2220B driven by Powersoft modules LITEMOD4HV : 1KW for each JBL...hipassed and lopassed and dsp´d actively between 65 and 550
"DIY" NNNN designed by Rune Skramstad ventilated one fold 4m basshorn with 18Sound LW1400 21" driver...lopassed, dsp´d and driven by same Powersoft 2KW channel
"PRE":
Hørning nanocrystalline AVC
RIAA:
all out quattro LCLC both pos and neg Borderpatrol designed powersupply for LCR Thorsten Loesch riaa...4xE810 with each individual psu
2MC and 5 MM inputs hooked up to arms simultaneously
WIRING:
Duelund silver(oil /cotton) to TAD TD-4003
pure silver foils in silk from Powersoft to midbasshorns
6mm multistrand copper for hornsubs
SOURCES:
Studer A727 wired both direct to AVC and to DAC
DDDAC 1794 4 stack /Rasperrypi3 "streamer" with BP designed choke input psu...separate psu´s for dacboard, R pi and Ian Kaneda /Accusilicon clock board
Day Sequerra FM Reference 25th Anniversary
2x Studer A80RC 2T 1/4", modded signal wiring and Nextel reproboards and MTSL record boards
Micro Seiki DDX1500 massloaded and improved psu with:
Micro Seiki Ma-505s/Koetsu Rosewood Signature Platinum
Micro seiki MA-505L/Kiseki Agaat Ruby 2
SME 3009R bronse bearing cart?
Melco 3560 with Hanze analogue regen psu and custom 4 tower ss316 65Kg custom cnc´d plinth with 5 Kg POM frame for bearing assy
arms:
Eugene Komissarow´s Harmony/DaVa Soul
Stefano Bertoncello The Peak 12" with DaVa mono
AM FR66s direct wired/Kiseki Blackheart
Alfred Bokrand Sonoro 12" banana with underhung counterweight direct wired from EIA connector to RCA/DaVa Reference
onboard SUTs S&B TX 103 cu and DaVa mono
outboard SUTs
DaVa ag/cu
DaVA cu
Parmeko
Supex SDT-1000
MCT2(Altec Peerless 4722 modern version)
in order and waiting
Consolidated ag 1:40 lo inductance lo imp
Consolidated ag 1:20 lo inductance lo imp
All signal wiring silver in silk unscreened except from SUTs or Red Rose(Mark Levinson) pure silver Litz
Power cables RS Components double copper screened 2x6sqmm
Separate 25A screened 3x10sqmm from breaker box
There is a whole playlist on my channel where you can see both iterations of his system play different music, not just rock, also jazz, small and large scale classical including emphasis on different instruments, vocals, and some in mono. https://youtube.com/playlist?list=PLKf6djSgyU2XoAz99MH6jpeomUrKtTc8w&feature=shared
One is on tape. The other is on a sub 1000 Dual TT with Shure cart, passive khozmo attenuator, both dual woofer FLH
And on lead guitar.,,Ritchie Blackmore
Allman Bros live from Fillmore East
  • Wow
Reactions: Sule22 and Rob181
Reactions: bonzo75
