Nice analysis on an n of 1, given that one of the Altecs is on a 4w and absolutely brilliant on black sabbath. Though 10w of the sans design amp was required for good symphony. It has more to do with the excursion difference between the Altec and the Admire audio, not the requirement
I'm having trouble sorting out what this means. 'n of 1' isn't landing. Not sure what you mean by 'excursion difference' either, or why 'not the requirement' ends the sentence. Could you clarify?
Do you know where in the mid band this distortion in the original TAD occurred ( 2 to 3 k?).
I seem to recall being told it was near the low frequency cutoff, but that does not square with the more relaxed presentation, so no.
With regard to subjective perception, I disagree.
In doing so, you would simply be wrong; I've no problem with the disagreement as I've seen this play out many times.
Again, this is one of the most common myths in audio and has been around for decades. Once one realizes it really is a myth, that knowledge allows one to put together a system that is more musical; more successful. A sister myth is that of equipment synergy, in that a dull sounding product is paired with a bright sounding product can be combined to achieve something in the middle. It doesn't really work. You can build a much more musical system if each component is there based on its strengths rather than its weaknesses.
I'm not arguing about electronics.
Loudspeakers are electronic and mechanical. Are you instead talking about something that isn't amps or speakers (like the overall combination of equipment in the particular room)? If so I missed that.
I'm reporting that at the very highest levels of reproduction there are subtleties and nuances of loudspeakers which even I can discern and which are more or less convincing with different kinds of music.
Right. We're on the same page there. What I'm trying to address is that those subtleties and nuances of loudspeakers might be more convincing on
certain tracks but
not certain
genres. That is why I mentioned sample size and why I could find examples that didn't support your claim. For example classical music spans a very wide range of material, such as songs sung with a accompaniment such as a piano.
What isn't mentioned here is how the 'girl with the guitar' was actually recorded. Did the engineer put a mic on the guitar and one on her voice (a common failing if you want realism)? We recorded a well-known local musician (
Paul Metzger) a few years back and he was astonished when we placed a single pair of mics about 10 feet from him rather than having one right on top of his guitar. But when he heard the playback he commented it was the most realistic he had ever heard.
The recording is likely paramount in all this discussion. Not knowing the provenance of their creation can lead to incorrect conclusions and is part of why I mentioned sample size.
I know you didn't intend to, but you just proved my point.
My intention was to support your statement with the explanation of why it works that way.
But there is no horn speaker like this to my knowledge, so it's a specious reply.
So far, yes, till someone sorts out to do that although it seems to me
@Duke LeJeune (Audiokinesis) built a speaker called the Dreammaker that had a rear firing horn. It was fairly efficient and an easy impedance; 16 Ohm IIRC. Again this was simply to support your point about planars.
