My Tube Collection, Welcome to share yours
Time for some tubes to enjoy a Spa Day!
Before ...
Soak the pins in a nice warm bath of Flitz
Getting relaxed and a pin massage ..
Now for a "pinacure" (tubes don't get pedicures!). Get rid of all the tarnish and oxidation.
All nice and spiffed up.
Even the back side.
Come and getter ...
Nice tubes
What is your choice of cleaning solutions and methods for pin cleaning?
Nice tubes
First level of cleaning is with 99% isopropyl alcohol.
For oxidation removal Flitz or DeOxit. DeOxit works well, but it takes a following wipe down and then wiping with the alcohol to remove any residue. Likewise with Flitz, t takes a following wipe down and then wiping with the alcohol to remove any residue. With Flitz, every application will remove more tarnish/oxidation - even when the pins look clean.
Once they are clean, I periodically clean the pins and sockets with KonTak. I use an interdental brush for the sockets and QTips for the tube pins.
By the way - Flitz also works wonders on AC plugs and IEC socket pins, especially copper AC plugs.
You can see the results here: pin, socket and connector cleaning
Reactions: jadedavid and CDawg
Bad boys. bad boys, whatcha gonna do?
These came from an eBay seller from Australia (decades ago) that had access to military/gov't surplus.
Flashing on the lower part of the tube, three holed plates that are mounted up towards the top. Mostly 1952 production from Sylvania.
Reactions: CDawg
Retired EML Globe 45v4 next to standard 45v4
EML Globe 45 resting while Standard 45 plays with power and grace
And for old times sake here’s a lonely original EML 45 with taller bottle from 2005!
Reactions: CDawg and oldvinyl
Variations on a Theme by RCA. Some of the 12AX7 variants I like for audio gear.
12AX7A - Low-microphonic version of 12AX7.
6681 - Special version of 12AX7 intended for use in mobile equipment powered by storage batteries.
7025 - Low-hum, noise and microphonics version of 12AX7.
7058 - High-mu twin triode for use as audio amplifier in mobile equipment. Has a 13.5 volt filament.
Reactions: CDawg
Nice tubes
I came across my Dremel tool and gave it another try. It works wonders using a buffing tool.
Tube pins before any cleaning:
Pins after cleaning with DeOxit:
Pins after duffing with Dremel tool (just cleaned one pin to highlight the contrast to other pins):
All pins buffed out:
Buffing bits example: silicone buffing bit
These Siemens E83CC turned out to be some of the quietest 12AX7/ECC83 I have tried.
My favourite! I have a few spares kicking around just in case.
Siemens E83CC is the best testing tube for noise I've seen on a Maxipreamp II. Seen a few guys including myself measure -89.5 dBv on a triode and the tester says -92 is the limit of a tube. Most other 12AX7 are about -82, some of the better ones around -85 and even on a good day at the factory there really isn't many examples beyond -88.
My ECC83 from France.
Lots of different French manufacturers so I thought I'd show a few nice ones you don't see a lot of. If you're looking at those "Mazda triple mica silver plates" I'd pay special attention to the construction and the factory codes.
20250809_105404.jpg20250809_105504.jpg20250809_105612.jpg20250809_105739.jpg20250809_105803.jpg20250809_111152.jpg
