Review: Atma-Sphere Class D Amplifiers
Thank you for your comments.
Yes, all the music used for the Class D review is on LP and each selection is listed with a catalog number for identification. I won't use problematic music material in my reviews. The video is on YouTube and plays fine according to other listeners and on my desktop playback.
OK - I tried the links in you Mammoth gold, and got a couple of clicks on-snaps. Then everything tripped in a massive click-thump!
(iPad —> cable —> RME ADI-2 Pro)
But… I found on-line that there seems to be an unplanned power outage.
So I doubt it was the YouTube. ;)
I’ll hunt for the second DAC and see if it gives more joy.
And I can’t even use the exorcise bike, as that thing needs power as well…
Nor can I do the dishes as the hot water needs power to trigger the gas to ignite.
This is only my second review that includes music examples via video of my system with the review component. The first was a review of the Aidas Mammoth Gold moving-coil cartridge which includes 3 YouTube video links. I'm not aware of other reviews that include system videos
Thanks.
Do you have any comparison with the other carts in the Aidas line up?
Which preamp are you using?
I have used three different preamps primarily with the MA-1 Silvers. First was an Aesthetix Calypso Signature (I also have kept the Aesthetix Rhea Eclipse), then a Atma-Sphere MP-1 Mk.3, finally an Aesthetix Metis. The last two when I had the Atma D-class amps.
Reactions: Verdier
A took the time to not just read it , but emailed myself .
Excellent review your wording seems very informative.
the video of your system is good
the dynamic range I think is tough on phone playback
but I took the time to use a good set of earbuds ones I know
it has good details and deep bass too
classical for most people including myself does not always convey the type of sound I love
But it remained clear and clean and massive dynamics as classical can have.
I even looked up your speakers as I am not familiar with them.
I do read your comments on many posts and feel your a very informed person
I’ve heard class d be horrible but also very good
at last years audio show ralph had an otl amp on huge acoustic panels
Also upstairs had same panels on a similar type mono blocks as your review
to me the class d performed very well on the panels
regarding videos I think for me its a big plus
I think it gives us a point of view that even your level of linguistics and details is helpful
Reactions: PeterA
Thank you!
@tima (some +/- feedback)
I think your YouTube video can be exonerated now… as I found the USB-C to USB-B was giving me problems with other streaming.
Hence I’ve ordered a new cable.
Reactions: Alrainbow
That Atma-Sphere YouTube video is only available through the review and it's had 271 views thus far. Seems like the idea of including a video in a review is working.
