I know this is an open ended question. But I wonder if there might be any 'quick' wins to a complex multi-wired system that is not suitable for lifters of anything significant but wondered if there might be some quick wins and considerations. I think I have nearly 300m of cable (possibly more) in an AV system
The system is silent other than very mild transformer hum (I do have something like 30 linear power supplies and 14 monopower amps with big toriodals) it is mild (You can only hear it when near the corner of the racks not from the listening position) and have evolved over many years. I do use internal vibration control with potting, damping material and copper chassis etc for sensitive items and like felt, certain resins, tape, etc. The racking is modest but reasonable given the amount of racking I need and the amount of bass in the room higher than most (I follow a harman curve to 8Hz and have 5 subwoofers)
So I can attempt to tidy but very difficult given the amount off cabling - I do run a relatively complex Signal and power GND set up to keep 0V as close to 0V in most cases and retain dynamics and a low noise floor
Be great to understand a bit more about this because the logic seems difficult to understand, surely carpet has some damping properties in any case ?
So any thoughts on quick wins ?
