I think this is balanced isolation transformer not AC regenerator? am I wrong?
This calculation is wrong. I c
So any regenerators rated at 2500 W or more is a sufficient source even for amplifiers that could output 60 or 75A.
agree.
i live in a modern housing development built in the late 90's, with a single transformer at the street for each multi--acre lot. out in the country away from any industry. then i ran a 100 foot conduit to my barn and used a robust 70 amp panel with all copper and it's own ground rod. used that for 7 years which sounded wonderful. conventional but solid.
at which point i added a 400 pound in wall mounted Equi=tech wall panel and 10kva regenerator which certainly boosted my performance all around. i can still switch to dirty power and my conventional 100amp HVAC/lights panel in my barn any time to A/B as i have those dirty outlets around my room.
it's not close.
sure it's anecdotal but seems obvious the better way to go.
I’m using the Torus rm 20. I’m thinking about possibly using a P15 (or 20) between my Audio Panel (made by Rex) and the Torus. All components would remain plugged into the Torus (including the 40 watt Aries Cerat amps).Torus filter corner is around 50,000 herts. Youe power plant is probably switching around 20,000 herts. The fundimental noise would not be changed. But the 3rd and 5th harmonic would be filtered, so it may sound better. You have a Torus, correct? Are you thinking of getting a P20?
i suppose we have to examine whether there is any real difference between an isolation transformer, and a power regenerator?I think this is balanced isolation transformer not AC regenerator? am I wrong?
I asked this question because I never seen 10KVA AC Regenerator in this market.i suppose we have to examine whether there is any real difference between an isolation transformer, and a power regenerator?
the nuance of that answer is beyond my pay grade. but on the surface they appear to do the same things in the same way. just a scale difference.
and at the end of the day limit dynamics and head room in most systems. i have 4000 watts on my bass towers (with efficient Class D amps) and 1000 (darTZeel 468's) watts on my 97db passive towers, along with lots of sources; i do have battery power for my preamp.I asked this question because I never seen 10KVA AC Regenerator in this market.
PS Audio P20, Strontank, Purepower, … all are under 3kva.
Try a Heartsound Audio Holostage or her panel device. Stick it on the panel and/or the Torus. I have a set of 4 on order and that is what I intend to do. Its a whole lot of graphene and piezo crystals. I gather its very audible, yet no one knows why. $1000 for 4 so inexpensive.I’m using the Torus rm 20. I’m thinking about possibly using a P15 (or 20) between my Audio Panel (made by Rex) and the Torus. All components would remain plugged into the Torus (including the 40 watt Aries Cerat amps).
I’ve heard about people using balanced iso transformers after the Power Plants with good results…
(Btw, is it unusual that my Fluke measurements - taken at Panel - don’t show any 5th harmonic?)
I have not seen a large regenerator either.I asked this question because I never seen 10KVA AC Regenerator in this market.
The since discontinued Richard Gray Power Vaults were 11kva units. They are around 1000 pounds and 4’ high - think half of a refrigerator in size - and cost $24k a decade ago when new. It’s a rebadged industrial (hospital use originally) UPS. I use one to bridge between my street feed and my whole home generator. The Power Vault keeps everything stable in between when the power goes out and the external generator kicks in. It feeds a giant Richard Gray transformer, which at some point will get replaced by a Torus unit. GE and Toshiba make similar units.I asked this question because I never seen 10KVA AC Regenerator in this market.
and relative to any other approach; a full system isolation transformer even including the installation assuming you are not rewiring all your circuits, is cheap, cheap, CHEAP......relative to any other 'High End' solution where you are paying for the market profile of big system investments and sometimes gussied up chassis and design.
Equi=Tech wall panel systems are commercial products, all business, aimed at Pro Studios and are priced accordingly. they have a very slight hum you can hear if you are within 3-4 feet of them. they do have a thermal fan which rarely kicks on. mine is on the outside wall in the hallway outside my room so never any concerns.
to me the ONLY reason not to go that way is if you are in a condo or apartment or home where there are logistical restrictions. otherwise it's a no brainer.
Battery psu in Dartzeel is very good idea. ASR Emitter also use battery in pre section.and at the end of the day limit dynamics and head room in most systems. i have 4000 watts on my bass towers (with efficient Class D amps) and 1000 (darTZeel 468's) watts on my 97db passive towers, along with lots of sources; i do have battery power for my preamp.
yet 10kva allows for at least X2 headroom any time even at full whip. which matters when things go crazy. and the whole system sees the same power profile.
The most important thing of Balanced isolation transformers is zero leakage current for all audio equipments, when we connect different equipments together each equipment has a chassis voltage (the capacitance between transformer and chassis cause induction voltage) and different voltage is not good for noise level and SNR. When we use balanced power all of these voltages are zero and SNR increase.Although balanced output mains transformers can be used for specific, not general use in houses, they need special installation and requirements - it is not a simple DIY affair.
IMO balanced power is only advantageous if the distance between the balancing transformer (or mains board) and system is very large or the system is very complex, self generating a lot of noise.
I had high quality ABB switzerland 20KVa UPS , all of new inverters and UPSs are igbt class d and they shift tonal balance and also decrease sound quality.Votronic makes larger sine wave inverters on request. They make for ambulances, so they offer the highest sine wave quality.
Rettung & Einsatz | VOTRONIC
www.votronic.de
