Should i surrender? Perlisten sub
Smart choice of -6dB ported sub-bass speakers for what looks to be a tight space.
All the best.
Beautiful! My gut and own personal experience says go with the larger. Generally have appreciate the air movement of the larger Velodynes vs their smaller equivalents. And the bigger ones never seemed 'slower' and generally felt that they offered greater air movement, power and effortlessness,
Arya Revopods installed under my new Peristen D15s
Detail of differences between Revopods vs hard rubber Perlisten stock foot…
Detail of Revopods installed….
General view of Perlisten D15s with Arya Revopods….
Final D15s placement….
Reactions: VPN
Congratulations!
I purchased two Perlisten D215S and hopefully will receive them by the end of February.
Can you describe the sonic effect of the Revopods on your Perlisten? Thanks
Hi VPN.
To put you in context, i’ve never been a sub fan.
I’be been searching always best sound with stereo system with only two speakers.
Sub was always discarded because its difficult to integrate because its false and different bass response vs main speakers.
After a lot of years of researching, my final setup is best i have found for my taste.
But in Hi-End we are living and learning….
This was until i detected different bass response of my system depending of my listening position.
Tads CR1 has very good bass. I’ve listened heavy bass tracks with authority and slam.
But balance wasn’t right.
Room response was the issue.
So i began to test different solutions.
Different spikes for speakers and electronics.
Different speaker placement.
Active bass trap AAVA C20.
Result was always worst than original setup.
I’ve talked with a lot of designers and technical people until i was advice that subs has an impact that few people knows.
You can control your room response.
Cancelling standing waves and at the same time reaching last octave CR1 lacks….
To avoid distortion and boomy uncontrolled bass, i tried Perlisten D12s sub.
This change was revelatory. It is so quick, resolutive, and configurable that i finally get right bass balance sound with longest deep bass.
Everything without changing my system style sound. Sub simple disappears with stunning synergy with Tad Bass.
As i would change CR1 to Ref1.
Sound was plenty in whole room without any trade off.
Important note: Cables have a lot of impact in sub sound. In my case i use Esprit cables.
Reactions: VPN and Brucemck2
Hi VPN.
Hi Stereophonic,
I am glad the Perlisten worked so well for you!
I would appreciate if you could describe in as much detail as possible how the sound changed using the Revopod feet vs the original feet. Thanks
Part ii:
With stock feet Perlisten is stunning.
But there is something i’m looking for too…
Now i have more bass, better bass and better room response from phase perspective….
I was aware that you even can improve mid and highs with right sub setup.
Understanding my room and experience with Perlisten i did upgrade to D15s who improve every parameter i’ve wrote.
Setup parameters are so long with a sound style base so great that i was sure D15s is a sub that always can play at high level.
Then i did remember my Revopod’s experience.
They are distortion killers.
Right energy is the key now, so i purchased a set.
Believe me. First improvement was better mid to high feeling. Tad sings more airy, with better space between notes, more expressive.
Even better that without sub.
Bass keeps extension but sounds more defined, better focused and with better slam.
Now i can fell the punch in my body.
Once i’ve removed distortion, i can feel my room sound less resonant. Energy now comes more from full system.
Room energy was the blame to tame mid to highs because room energy resonance.
Sound begin and ends faster improving full dynamic and resolution.
Now i have not only better bass, i have better full range sound.
My musical listening experience has grown at a level i didn’t expect.
Hope that helps… :)
Reactions: VPN
This should be expected with a well setup 2 + 1 speaker system. The main benefit of adding a sub is not necessarily better low end response but the overall improvement in all aspects / parameters of sound quality. A much more full bodied, dimensional, emotionally involving listening experience.
If not, then something is amiss.
The very best subs I've ever heard are those from Ascendo, a German audio speaker company which has been around for about 20 years but only fairly recently made some inroads into the US market. They've taken a "system approach" to subwoofer design. Meaning that just as a traditional speaker uses multiple drivers for specific frequencies, so does an Ascendo sub system. I was so enamored with them for music (and home theater) I made the decision to add them to my system.
In my case it is a combination of THIS 32" Infrasub along with 2 of THESE Dual 18's"kick subs" (as named by Ascendo). Each of these are driven by one of THESE amps (ASCENDO DSP4-10K2). In the case of the 32" each of the two voice coils is powered by 3000 watts and in the case of the 18's each driver is driven by 2500 watts.
While the "Infrasub" nomenclature is used to describe the 32", 50" and 80", there is very little music (or even movies) that make much use of those frequencies. But what you do get is the ability to instantly compress all of the air in your listen space so that, for example, a recorded drum "thwack" (or, in a movie, a powerful gun) takes on a whole new dimension. And with the amount of air moved, even subtle more traditional bass becomes much more audible and adds so much to the listening experience. A "not for everyone" solution, but if you have the space and funds, go find a place to listen.
And for those of you who think large subs must be slow, that is most certainly not the case with these. Their impulse response is most impressive.
And for grins, here I am, the old(er) 6 foot tall guy along with the 50" Ascendo and two Ascendo Black Swans (and the owner of Atlanta Home Theater). This room is a holding place for these 3 pieces as the purchaser has yet to finish his listening space. Even with almost zero room treatment in this space, you could certainly hear some the positives of the Black Swans - AND the 50" sub.
My bad. I incorrectly assumed it was about "subs" and not necessarily PERLISTEN.
I apologize for derailing your thread.
Isn't this a thread about the Perlisten subs? Why do people keep posting about other subs here? Shouldn't them post elsewhere?
So any mention of any other sub(s) or anything sub - related is not permitted? Ridiculous.
Reactions: VPN
Thank you @ecwl
I’m not a fan of technical measurements.
One reason i don’t like subs is they have infinite combination of settings and they are very difficult to balance with speakers.
I see that a bit differently. With the right tools, and experience, it's really not difficult at all. But like it or not, it requires technical measurements to achieve the proper results.
Reactions: VPN
Agree that you can't simply play a few tracks like I've even heard "professionals" state to dial in bass and subs. Our ears and musical tracks can't capture every low frequency to assess modes (peaks and troughs), decay, etc. You have to measure to see and adjust. However, dialing in subs, especially multiple is not easy. It takes time, patience and experience as each sub affects the overall sweet spot bass.
Reactions: VPN
"...its distortion output above 20Hz is the cleanest I have seen on any sealed subwoofer and pretty much any subwoofer I have yet measured. At 100dB and lower drive levels, the D215s can’t surpass 5% THD at any frequency. While we have seen examples of subs that can maintain lower distortion below 20hz, the D215s puts up a remarkably good performance level, and it is pretty much untouchable for undistorted sound above infrasonic bass regions...."
Reactions: sbo6
I have received my two Perlisten D215s. I am using them with Echole Limited Edition mk2 power cords and Echole Limited Edition mk2 XLR interconnects, and a set of Revopods under each. The revopods made a relevant positive difference.
I am currently using the two Perlisten with my heavily modded Dunlavy SC-VI (picture). The two 15" woofers of the Dunlavy play below 75hz, with a second order crossover. I disconnected the two 15" woofers of each Dunlavy from their external Duelund crossover and I am using de Perlisten D215s instead. The integration is quite good and they disappear quite well, same as the Dunlavy. The lowest frequencies are now more detailed, while still very fast and extended. Quite happy with the Perlisten.
I purchased a pair of Rockport Orion, which should arrive early next semester, so I will probably cross the Perlisten very low, maybe at 30Hz, to complement the 13" bass driver of the Orion. I have heard the Orion with and without subwoofers, and in my system/room the Rockport Orion, for my preferences, sound much better with a top subwoofer.
Reactions: Re-tread
Beautiful! Would love to read more about how the 2 Perlistens have improved your overall experience: how much greater sense of air/space/venue are you getting, perhaps scale as well...and of course given the crossover, what happens to the performance of the mains when you are crossing them over? Enjoy!
Reactions: VPN
Thank you!
Now my CH Precision M10 is driving only the two 8", two 5.5" and tweeter of each Dunlavy, so that extra power added a bit more detail, a bit more control, and maybe dynamics in midbass/mids/highs.
Regarding the crossover of the Perlisten, I have kept at second order and have been experimenting with the crossover frequency between 70hz and 82hz and with the level. Currently at 82hz.
Regarding the sound where the Perlisten play, where the Dunlavy dual 15" used to play and now the Perlisten, the dynamics is the same as it was before, since it was already very dynamic. What I hear now is more detail, better instrument timbre/texture at the lowest frequencies. Probably much less distortion, but I have not measured.
Since the Dunlavy already has two 15" each, it is quite extended in the lower frequences (besides high frequencies), so I purchased the two Perlisten mostly to complement the Rockport Orion that is not as extended in the lowest frequencies.
