Of course, we all share our experiences with each other.
I have a peak at ~120 - 230Hz which results in a bit of warmth, so difficult to assess any difference in lower mids, I hear and measure none.
I notice more effortlessness and impact in the overall bass range and to be honest across the spectrum (maybe it's the bass driving a perceived benefit across the FR?). Note: this is with an almost identical frequency response versus before using the Active XO. My guess is - this is from a significantly lighter load on the amps. If you look at my Spirits' impedance curve, the front 3 drivers (@220Hz - 20Khz) are very easy to drive, but the 2 11" woofers dip to ~4ohms at 220Hz, 85Hz and lowest at 3.5ohms at ~19Hz (minimal effect I'd surmise with little content this low). So crossing over at ~70Hz eliminates much of the higher current demand and provides that big, effortless, dynamic benefit which is what I think we're both saying.
The key is the right crossover points with the right rolloff and optimum phase integration. To me, you can't do this without measuring.
