I got those absorption panels over a year ago when I was struggling with brightness/edginess issues. I am not hearing any such issues today.
From which you have concluded ?
I have concluded that I might not need the sidewall absorption panels anymore.From which you have concluded ?
(Although it's a bit puzzling because I have always thought it was standard audiophile acoustic practice that first side wall near reflections and first side wall cross reflections should be diffused or absorbed.)
I think he had concluded it was more in the Pendragon speakers from the BG planar driver...correct me if I am wrong, Ron.I was thinking more along the lines of component changes within the system , from the time when you first perceived the slight brightness that bothered you to your current configuration and whether you might have identified a potential culprit (s) for this glassy edge that is no longer present ?
Sounds plausible .I think he had concluded it was more in the Pendragon speakers from the BG planar driver...correct me if I am wrong, Ron.
So, the goal is to make 213Cobra dislike your system somewhat less than before?Phil has visited me numerous times, and he has never liked any iteration of my room + system. This visit was no exception,
So, the goal is to make 123Cobra dislike your system somewhat less than before?
Why would Ron even care, isn't he a Zu owner ?So, the goal is to make 213Cobra dislike your system somewhat less than before?
I have no goal for my system with respect to 213Cobra's preferences.So, the goal is to make 213Cobra dislike your system somewhat less than before?
Has he told you specifically why he has never liked your system? Or is it just not his cup of tea?
Why would Ron even care, isn't he a Zu owner ?![]()
he, too, prefers the sound with the side wall absorption panels removed. I'm not hearing what these guys are hearing, but with the absorption panels removed I am not hearing any sonic or acoustic problem.
I see your system history as an ongoing lesson on displacement of many assumptions by actual listening experience.
Perhaps it is not a problem so much as it is not recognizing what you don't hear.
Live acoustic music is vivacious. What 'these guys' may be experiencing with the panels in place is an overly dampened sound or reduced liveliness or lack of energy in your room.
Also here it depends. Live acoustics vary..
So, you don’t hear the thinness of tone or flatness of soundstage or smearing from multi-tube output stages of amps, which he claims to hear in your system?I would prefer Phil to enumerate the reasons himself. Among other things of which I can recall just off the top of my head: he does not like VTL; he does not like Aesthetix (I believe Phil finds it thin-sounding); he likes only sensitive or very sensitive loudspeakers; he does not like massed output tube amplifiers; he hears no depth to the sound-stage, just flatness.
Phil has always kindly said "I may not like your components or the way your system sounds, but I'll always try to help you make it sound as good as it can be." And I appreciate that sentiment.
IME, if Ron listens to music he likes and as long as it is not bright (to him), he doesn't care.Or rather, do you hear all that but you connect well with the music and don’t care?
