If a Belden/Mogami routinely exhibits a touch of edginess, and a fancy cable does not routinely exhibit that touch of edginess, how do you know the Belden/Mogami is "doing no harm"?
This start to look like a gramatic course in english! Perhaps THAT will enhance the sound quality - who knows
Hi Peter,I once owned fancy cables that enhanced aspects of the presentation. I sold them.
Sins of omission are still sins…On a universal basis of course not, but from my direct experience and for my preference they are less editorializing. I only know what I've heard or reviewed over the years for the components and systems I have had ... that I can remember:
Alpha Core Goertz
Audioquest
Crystal Cable
FMS
Kimber
Kondo
LessLoss
Shunyata
Silver Audio
there are others but I'm not at the right computer to look them up.
More likely your fancy cable is not letting the edginess trough when it is on the recording, if it is only occasionally, and that is OK if it is your preference.If a Belden/Mogami routinely exhibits a touch of edginess, and a fancy cable does not routinely exhibit that touch of edginess, how do you know the Belden/Mogami is "doing no harm"?
I hear an occasional touch of edginess from the Belden. I prefer the Cardas because it sounds more natural and organic to me.Have you heard “a touch of edginess“ from either of those cables or from a RadioShack cable?
I am not sure we have the same definition of "harm." If a cable sounds edgy, then I consider that to be a harm.And if you have in a specific system context, did they do more harm than an audio file cable in the same system context? Please site specific examples.
Well that opens up big cans of worms!More likely your fancy cable is not letting the edginess trough when it is on the recording
I think you once stated that you want a cable to sound warm.
So, you use industrial wire as well?More likely your fancy cable is not letting the edginess trough when it is on the recording, if it is only occasionally, and that is OK if it is your preference.![]()
I figured I would throw in my 2c. Why not kick off the new year with some cable discussion.These are just my opinions dispose of them as you wish.
Why single out cables? All components editorialize the sound. Compare a 300B tube amp to pretty much any solid state amp. That is a pretty big knob to turn to swing the sound one direction or the other. And just like any other component, there are cables that sound very similar and there are cables that sound very different. Some cables are blurry and there are cables that are precise. The blurry cable will sound 'nice' -- some may call this 'warm' sounding. The precise cables will be articulate and clean -- some may call this analytical. It depends on what type of experience you are looking for with your stereo system. A loom of cables should be treated just like any other component. This 'component' has potentially the same level of impact as anything else -- preamp, amp etc.
No not at all, i prefer pure copper cables with a neutral sound. Silver is often too focused on treble energy for my taste, some of the more muffled copper cables are too dull. Some Cardas cables are in that " muffled" category, i also had the impression Ron preferred a warmish cable.So, you use industrial wire as well?
Sometimes you are soo funny KedDo all silver manufacturers source from the same mine?
No, and some sound different, i have just never encountered one i liked the sound of. They often go well hand in hand with the muffled sound of tubes.Do all silver manufacturers source from the same mine?
Do you find silver transformers do similar things to silver cables?No, and some sound different, i have just never encountered one i liked the sound of.
I have never tried a silver transformer. Do you mean silver step-ups or power supply transformers ?Do you find silver transformers do similar things to silver cables?
