The second video sounds out of phase, are you sure the cartridge is connected correctly?
Hello Rexp. I first checked the XPP which has the channels reversed so I always have to remember to switch the left and right channels when putting the cartridge in the headshell with the leads. I then checked the GS and it looks correct but just to be sure I switched the positive and negative for each channel. The sound became slightly less focused. Then I played the Cardis test record, which has a track for polarity and confirmed the cartridge is correctly marked incorrectly wired for polarity. Then my preamp has a phase switch and I tried that.
While I was experimenting, I did play with anti-skate, which was already on the lowest setting at 0.5 g. The recommended is .2 to .4g. So I disabled the anti-skate and it sounds better.
My conclusion is that everything is correct. The GC seems to have better ambiance and more air. I wonder if that is what you were hearing. Thank you for the suggestion. The Cardas LP has a very nice write up on the effective polarity and what you will hear with certain instruments.
