And i am talking about real four column speaker systems not puny little speakers !![]()
Yeah i know .
Id love to hear a martin logan system like yours
Speakers with limited bass output do not count !My Acoustats could do no problem and no my hearing is fine thank you![]()
IME horns, while more directional than cones aren't any more directional than panels. In fact, horn drivers need more distance to integrate well at the listening spot, and your room is of modest proportions (like most of us). As such, (not to mention I haven't heard a single pair of horns that integrated well and never sound natural to me) I'd recommend the Clarisys Minuet. I know folks who've heard them and rave about the natural tonality and uncommonly incredible dynamics. Good luck in your pursuit and enjoy!
I dont agree at all .
You can may be get good coherence at 1 m
from small 2 way system
Im talking big 4 way systems , like my XPE .
Thats a shortfall of the Wilson XVX system, to High / multiple stacked units resulting in not a coherent sound output .(to my ears at least).
One of the best , if not the best coherent LS is the Rockport Lyra
The more units a speaker has in general the more stacking occurs , thus the more distance is required to make them sound as a whole.Then all are not coherent designs your 1M testing will show this ..!
At 8ohm 2.83v and 4 ohm 2.00v= 1wattMeasuring sensitivity with one watt at 1 m its a standard Spl measurement. at 1 meter mic distance
When i design loudspeakers i do may be 50 measurements ranging from 1 m to 4 meters .
At different angles as welll to get the full picture.
And make X over changes accordingly
there is usually a little cheating in favor of the manufacturer
Yeah but you should hear what a monocoque design can really do .And i am talking about real four column speaker systems not puny little speakers !![]()
The drivers need a certain distance to blend
They were 2.4 meters tall and 55 cm wide and were flat to 20hz with tremendous bass…even better than my Infinity IRS betas with 4 12 inchers per side.Speakers with limited bass output do not count !![]()
I can really second this recommendation.I could imagine that the horn driver and bass driver opus 1 are selected again (matched), so cessaro actually uses tad&supravox drivers. But there are also now in-house developments. I can't say anything more specific.
Now in the german audio market
Cessaro CESSARO OPUS 1 + SUB (2156722613) | Ausstellungsstück | Standlautsprecher | Angebot auf audio-markt.de
Angeboten wird „CESSARO OPUS 1 + SUB“ von Cessaro als Ausstellungsstück aus der Kategorie „Standlautsprecher“ bei audio-markt.de - dem Online-Marktplatz für High-End. Das Inserat mit der Nummer 2156722613 endet am 28.12.2025 um 12:59 Uhr.www.audio-markt.de
Stacked or linesource? the point is you can make a FR speaker fully coherent at 1M ..!
Its been done for decades ...!
If you want to specify the sound pressure level of a loudspeaker, you have to specify the impedance and the voltage used. For example, if you have a 4 ohm loudspeaker and the standard output is 2.83 volts, that is 2 watts of power and not 1 watt as with 8 ohms. So the loudspeaker has 2-3db more than it actually has.Not cheating its 2.83V test voltage , not referenced to 1watt . If using 1w/M then you have to specify such ..!
You must be running steep slopes or ceramic drivers or both, their out of bandwidth performances are not really up to par so i can see coherency problems ..!
Do you measure anechoic ..?
Wow, can you share a pic of your system?I use 16x 12" woofers and 16x 7,5" for mid-bass.![]()
Can't be done at 1 m, you need a big room, with distance to your listening position. Deep bass does not even develop at 1 m, i have set these systems up 25 years, in real life, not just theorizing in audio forums.4 tower system or multi tower systems can do so too if the mains are time coherent and balanced .
You have to balance how the bass towers integrate on the ML thats not so good when done right you cant even hear the bass towers it all should appear to come from the mains ..!
