Now i ask in the biggest italian forum if somebody listen
grazie mille!
videohifi.com
is the biggest but people with big system don't write in any forum
So you find only medium/cheap system
Only 3/4 with big system write
videohifi.com
a friend of mine heard "La Scala" and was not impressed.
But to be honest I never heard such DAC.
He preferred Bricasti instead.
A question for Mike or Edward
If the Formula plays up to 384 why do you convert everything to 352.8?
Did it sound better at 352.8 than 384?
If the HQPlayer can convert to 384 did you and Edward try this
Hi Steve,
Excellent question. Not all of the filters in HQ Player can handle non integer multiple upsampling. So to allow for all of the filters in HQ Player to work going up to DXD, I chose 352 for the initial sound tests to give the maximum number of options for 16/44 material.
Sometimes there is very little audible difference between upsampling at an integer multiple or non integer, For some filters non integer won't work at all. With the Aqua Formula the sound is so good, we find there is quite a bit of flexibility in choosing filters.
On the operating system side, there are choices for processing priority which are pretty system specific. It can be some what complex, but we have been deep into this stuff on a lot of installs, and we know our way around. It's also important to let everything burn in before rigorously testing, as the optimum filter choices will change as the system noise floor drops during the running in time.
you lost me
You did try it and it doesn't work or you did but it didn't sound as good as 352.8
you lost me
what Ed assumes is that you realize that his thinking is based on the CPU doing the least math.
you have 44.1->88.2->176.4->352.8......and 48->96 ->192 -> 384
and even you have a 44.1 clock and 48 clock.
even some dacs are optimized for one tree or the other.
switching sampling rates back and forth between the 44 tree and the 48 tree can degrade things.
so staying with the 352 allows the 44.1 redbook to be optimized.
I get that Mike. It's not a mystery. I merely asked if it was tried and if so what you heard. I guess there are 2 clocks in the Formula if you get to 384 so it was merely a question on my part
ok, sorry.
I did not personally change the filters and don't know which one I was listening to when Ed switched them.
That's good to know Edward. Is it that the filters on HQPlayer are not as resolving at 384 than at 352
What were you hearing on Sunday when playing 384
