Hi there
I need some advice ordering a Golden gate lampizator
there appear to be a few options
single ended or balanced
in SE you have a choice of tubes not balanced 101 D only
although my system is balanced the distributor recommends SE
this will give me more tube options
I mainly listened to classical with a little jazz
Is 101D the way to go
as most of my if not all cd and dsd is on computer should i ask for other options i don't you a server
thanks
Andrew
thanks
Andrew
