One of the most frequently asked questions from women is "How do I get away when a guy holds me down on the ground?"
In this photo sequence, we'll examine how a smaller individual can use leverage to get out from underneath a larger attacker.
Here, the bad guy has tossed our heroine down onto her back and is closing in to control her:
Notice that our heroine is instinctively doing the correct thing: getting her feet between her and the attacker. Here's another look:
If there is sufficient space between her and the guy, she can put her feet right into place. Often, she can only move one foot at a time:
The goal is to place both feet in the "frog" position (feet out in a "V" shape) on his hip crease:
From this position, she has the leverage to push him away very powerfully. You can try this at home with your significant other, but be kind!
Of course, we posed the first sequence for clarity. In reality, the attacker will not be so accommodating. Here, in a more realistic scenario, he holds her down on the ground and pins her with his weight while he starts to choke her:
Notice that she no longer has the space to put her feet on his hips to push him away! So, she must make the space to use her legs as shown in the earlier photos. Most all people do not possess the upper body strength to push a heavier attacker off of them while being held down, so using the stronger musculature of the lower body is the most efficient means. In order to get her feet into position, she must make space between his hips and her body. Once again, using the leverage of her lower body, she'll move him just enough to get her feet into place. She'll wrap her legs around his waist and lock her feet together, giving her a firm grasp of his torso. A bonus is that male attackers typically don't see this as a threat! If her legs weren't long enough, she could squeeze her legs together to gain as much traction as possible as she moves him away.
Continued...
Continued...
