What are the Top Horn Speakers in the World Today? Vox Olympian vs Avantgarde Trio vs ???
Agree on selection of drivers , design implementation and crossover design is (for all speakers regardless ) critical , Disagree completely, it wont deliver every ounce of dynamics on a non pam pam amplifier..!
Once the loudspeaker system is capable of delivering the necessary peak db level it will deliver full dynamic expression of any recording. So whats critical is the ability to hit dynamic peak with the lowest distortion.
Criteria :
A. Large enuff surface area , which does require multiple drivers . ( 50% lower thd for every doubling of surface area )
B. Power Handling capability without compression.
C. Low Driver mass vs BL
D. Full power bandwidth 30-20K.
E. Proper crossover design with good Transfer function ..!
These are known knowns , not new to loudspeaker design, regardless of high sensitivity vs low sensitivity approach.
As to efficiency thats expressed in percentages so i think its best we stop following accounting principles by calling everything efficiency..
If everything else fails lets shoot for 1 acoustic watt ..
I agree with you on surface area, power handling, BL/mass, bandwidth, and crossover design, but I’d add this: peak SPL alone doesn’t ensure true dynamics. Real dynamics require enough sensitivity and a stable impedance for transient current, low thermal/mechanical compression, and proper crossover/transient behavior to keep both micro- and macro-dynamics intact.
Reactions: Ligriv and morricab
Criteria :
B and E are the real problems with your “just put in more power” approach. Low sensitivity and low impedance drivers do suffer from thermal compression and complex, high order crossovers soak up power that robs dynamics.
Reactions: Ligriv and Kozak170
Conjecture for sure , not to mention the complex high order crossover thrown in from far left field never discussed ..!
PS: Your response has nothing to do with what i posted , Beee jeezus the ignorance is astounding..!
This is not single driver theory or approach , we are discussing systems..
This is not single driver theory ..
Thermal compression is real and not conjecture. Most multiway speakers use complex filters of 2nd or higher order. It has everything to do with your post, maybe think more…?? After all your A says you need multiple drivers…this usually means a multiway crossover…except for a very few designs like Grandinote and Horning. No one is talking about single drivers here…
Reactions: Ligriv
Compression is one of the most critical factors in music reproduction and one of the most often overlooked topics. Other areas must also be addressed, including time and phase distortion; however, get those right, and you're well on your way!
Amps matter to when it comes to compression. Some of the images of the AG have big SS amps driving them. I put my Audion SET 845 in and I can't stand how muffled and fat the bass sounds. Its run for 3 days now. My KT88 PP are much more articulate and dynamic.
This is completely untrue. I spoke to David today. I think he is wondering why you make stuff up. You should email him and check.
i think my misunderstanding came because David made this remark
"and bonzo is right bypass Sophia & Sasha v1 for v2!"
on a thread where I had a few posts earlier mentioned sasha 2 is better than previous versions including Alexias - on memory I did not remember he had qualified only with Sophia and Sasha 1, because I have been on in various posts against the bigger wilsons, and here it was the Alexia.
Reactions: abeidrov
That said, when opening a thread with such a rather superficial and provocative question, it would actually be helpful to first clarify what should properly be considered a horn loudspeaker in the first place. Shouldn’t all ten octaves ideally be horn-loaded? Or is it sufficient if only four out of ten, or perhaps five out of ten, are?
Best regards,
S
Let me give you some context for the thread: we all see things from a different perspective. My goal is to find the best horn speakers for me. A rational decision making approach calls for selecting a good handful of speakers to audition, before selecting one that meets one's subjective preferences and one's goals. Hence the title.
You bring up interesting points about horn-loading all the octaves. It may be important to you, but obviously not everyone agrees. Please convince the audience why this is better or critical from your perspective. thanks
Reactions: microstrip
This probably has more to do with output transformer saturation than compression/dynamics per se.
Reactions: Kingrex
Brad, please think about these questions:
- wilson benesch use no crossover for midrange but it is not more dynamic than Wilson Alexandria.
- Wilson Alexandria does not use first order crossover but it is as dynamic as good horns (horns with first order crossover).
- Aries Crates big horn was very compress in munich 2024 It was even less dynamic than small wilsons.
- WAMM in Munich 2025 was more dynamic than some horns in munich 2025
- big WE horns were the most dynamic speakers in the show but not all horns are as dynamic as WE horns
The specs/theories are not the whole story of design.
The key is our listening skills to understand which loudspeakers are more advanced
