TTs with multiple tonearms
bonzo75
25,691
16,994
4,490
London
Hi all, which TTs have multiple tonearms, and how many here own such TTs with more than one tonearm set up?
I know TW Raven, Verdier, Kuzma Stabi XL and Techdas have that facility
Awesome Halcro, which TT is the second one, and which are the respective arms and carts that you have on them?
Ok, seems a Direct Drive Victor. What's the rest of your system?
That is a Victor TT-101 DD set in a purpose made solid polished granite cradle with purpose made solid bronze armpods supporting a Fidelity Research FR-64s, an SAEC WE-8000/ST and a Dynavector DV-507/II.
On the Raven AC-2, there is the DaVinci 12" Grandezza Ref, the Fidelity Research FR-66s and the Continuum Copperhead.
Putting records on either of those TT must be like playing a game of Operation! :)
Sorry to trickle down the questions, but which carts? I heard the same Da Vinci on Thorens Acrylic yesterday, with top of the line Jan Allertz cart
Wave Kinetics NVS direct drive turntable, with -2- 12" Durand Telos arms. the NVS is one of very few tt's that can handle -2- 12" arms without needing pivoted/cantilevered arm boards. the NVS sits on a Herzan TS-140 active isolation platform. both arms are plugged into separate phono stages in my new darTZeel NHB-18NS preamp. siting on top of the pressing is the Durand Record Weight.
the arm on the left side is the 'stock' 12" Telos with the composite arm wand. I use it for my mono pressings and it has a Miyajima Premium Be mono cartridge.
the arm on the right side is the Telos Sapphire with composite arm wand. the Sapphire has 'special metal' weights and sapphire bearing tower, an inverted bearing, and sapphire pieces for it's azimuth bridge. it has a stereo Ortofon MC Anna cartridge.
Reactions: amadeus
From the VPI lineup; Avenger can do 3 and Classic 4 can do 2. Also, they are coming out with a second arm adapter for the Prime eventually.
That is a Victor TT-101 DD set in a purpose made solid polished granite cradle with purpose made solid bronze armpods.
Would have been my Suggestion also, mighty fine indeed Halcro:cool:
Clearaudio innovation, master, and statement.
Verdier
VPI classic 4 and Avenger
Brinkmann - various models
AMG v12
Techdas various
Acoustic Signature
Transrotor various
Sorry Bonzo...didn't see your question on cartridges...
I have over 40 cartridges so the choices change on a regular basis (except for the Copperhead which is a 'pig' to work on..:mad:). So Signet TK-7CLa on that.
Infinitely better to have multiple tone arms than to have multiple turntables!
A second turntable just be being there physically can have a degratory effect on the rest of the system.
but with only 2 arms, the user would have to choose between vta adherence or mono imaging solidity.
Dr. Feickert Blackbird, Firebird (easiest/most felxible tonearm setup imo)
Halcro - you are my new role model - not crazy expensive and you love to swap between different arms, carts, etc.
I assume you like Koetsus. Do you have a Coralstone, and where are you seeing the best combo? Same for an Ortofon A90/95/Anna if you have one?
Any other cartridges that make you go Wow?
Asking from the point of view of tone and realism on individual instruments as well as separation, slam, and dynamics on complex orchestral
Haha...thanks Bonzo. Not so sure I will remain so......
I prefer a lot of vintage MM cartridges to LOMCs and some of my favourite MCs are also vintage like the FR-7 series and SPUs....
https://systems.audiogon.com/systems/758
Here is my System Page from Audiogon...:cool:
It's not really up to date as I have several more cartridges which are not yet added like three Victor X1 and Z1 as well as the AT33MONO and the SPU Silver Meister...
But what really made me go Wow was the London Decca Reference I just acquired
Sorry photos are so large. Don't know how that happened...?
This is the new model from Bergmann Turntables till 4 arms air bearing and vacuum pump.
