I finally upgraded from my stock (MS) USB cable to a Transparent USB, my rationale was that whatever above a stock cable would work. I have about an hour listening to it now in the system and it is a revelation!
Let me guess: the sound is clearer, right?(Somebody was gonna' say it!)
There are many valid reasons why a better USB cable could sound better. I strongly suspect a good $10 cable will sound better than a bad $100 cable, and that mesaurements would show why.
I am sure Don can add more to this but in general, the faster the rise time, the less jitter can be induced. And faster rise time requires higher bandwidth. The challenge is that we don't know the transceivers at either end so it is hard to generalize too much here.I was told that one of the primary parameters for USB cable performance is the speed limit of the cable. Any comments?
Lee
Tell you one can "see" a big difference between HD!I cables on a TV. Just compare the crap your cable company gives you and even a better quality MC HDMI cable!
You purchased from Stereo Design? How much is the USB cable?
Do you see any value in USB cables (that supply signal to DACs that have separate power supplies) which have their internal power lead cut? So, there is no power passed down the USB cable during playback.
Lee
Yes, Lee in my experience you get two benefits from using a USB cable with no power carrying wire:Do you see any value in USB cables (that supply signal to DACs that have separate power supplies) which have their internal power lead cut? So, there is no power passed down the USB cable during playback.
Lee
^ I was playing off the "Transparent" name, sorry for the bad joke!
I've lost my will to live.
The cable may or may not be snake oil, but regardless, it's not because it's "literally a bunch of ones and zero's". There are no 1's and 0's when we store, manipulate, or transmit digital data.
What there is, is some form of signal that represents 1's and 0's.
If we assume the signal is some kind of voltage, there won't be 0 voltage representing the binary zero and there won't be some other maximum voltage representing the binary 1.
A crude analogy ... if the acceptable maximum voltage on a digital transmission protocol is 800 mV, then the 1's may be represented by 600 mV and the 0's may be represented by 300 mV. A zero voltage will never be used ... everything electronic is too non-linear at the minimum and maximum (that's why we bias transistors).
A signal of 450 mV in that case would have to be accepted as one or the other binary number. Errors arrive when the signals stray too close to the threshold where one state becomes another.
If we used a true zero voltage as representing the binary 0, then certain types of noise would be interpreted as 1's. So we don't.
In practical terms, although the above is used, what is more common is the use of states. A signal is transmitted when the state changes. So a signal of some kind indicates "change from whatever state you were on (could have been a 1 state, could have been the 0 state) to the other one, and stay there until I tell you to change again." Whether its within the CPU or via a cable transmitting digital data, all this happens in a stubbornly analog world.
