You can get something like an Audio Note Kits DAC for a couple thousand that will sound more natural...just as one example. There is no need to accept this kind of sound just because it is cheap (although the top ones are now not so cheap anymore and there are similarly priced alternatives that sound better but measure "worse").Just to weigh in here — I think this discussion misses an important point about context.
Yes, compared to ultra high-end DACs costing 5–20x more, a Topping DAC might lack some of the harmonic richness, spatial layering, or "organic" texture you get from top-tier tube or R2R gear. But that doesn't justify calling it flat, grey, or compressed — unless you're completely ignoring price and value.
The reality is: Topping DACs outperform most gear in their class and even rival components at 2–3x their cost in terms of performance, transparency, and detail. They are neutral and accurate — and for many listeners, that's exactly the point.
Dismissing them because they don’t sound like a €10k Lampizator feels like comparing a well-engineered sports sedan to a Ferrari and saying the sedan is “lifeless.” It's not — it's just targeting a different use case and market. You can say a DAC lacks certain traits compared to high-end gear — but labeling it ‘flat or compressed’ ignores its actual performance and the fact that, for the price, it punches far above its weight
Appreciate both perspectives here, but let’s not lose sight of the incredible price-to-performance value these DACs offer.
Please note, this is WBF and not Audioasylum or a forum where budget is the primary concern. If you care about your sound being natural then there is no way you can accept DACs like the Topping, sonically.
