Hi Mark, Been a while...wow!...Congrats on the Bernings...i have heard they are incredibly sensational amps.
Replied by email
I do not have balanced inputs on my amp. Will something like this be beneficial between T+A and My amp?
http://www.ebay.com/itm/Jensen-Tran...193326?hash=item54162b5c6e:g:K2oAAOSwKrhVXQnd
Marc...I would be most interested in your impressions having performed the bypass . I am giving serious consideration to this DAC running balanced line output into an ARC Ref10 pre.
Hey Priaptor.
I am not currently running a DAC, red book CDP only ATM. However I am particully interested in completing an all Ballanced chain as I am currently running Single ended from source to Ref 10.
I have more than enough valves in my system as it stands, without adding more at source, and the T+A ticks a number of boxes, not least a comfortable RRP considering its reported efficacy.
My incoming preamp is single ended. My Rogue amp has transformer coupled balanced input but still not truly balanced. According to the report, I should be using balanced output of the T+A dac.
Can anyone please suggest the best way to take advantage of the balanced output of the T+A dac when the rest of my system is not balanced?
XLR to RCA cable vs Jensen transformer vs something else?
Which Rogue amp do you have, valve or hypex output section?
I have the Rogue ST 100 which uses KT120 tubes.
Appreciate your helpful suggestion! Unfortunately, my incoming preamp (Linear Tube Audio MZ2-S), only has RCA input. So, if I want to keep it in the chain, I've to use RCA throughout i.e. also use the RCA input on my Rogue amp. I don't have a balanced cable lying around right now. Otherwise, while I wait for my preamp to arrive, I could connect the T+A balanced out directly to my Rogue amp.
According to user feedbacks, T+A sounds significantly better through XLR out. Given the rest of my system is single ended, how do I take advantage of T+A balanced signal?
Try what Ric suggested in post #119. It will keep the preamp in the circuit and it may sound better than RCA. The T+A sounds fine with RCA but does take a big leap with balanced. Unless you hear the two side by each you wouldn't know.
Thank you Quadman! According to Ric, it works best when the balanced output of the dac has summing circuit. Any idea if that applies to T+A balanced out?
Ric also wrote "you might want to try a xlr to rca cable that has an xlr on one end that has just pins one and two connected and leave pin three unconnected and an rca on the end going to the load."
Right now, I have a HiDiamond D7 RCA interconnect that does make a difference in my system compare to other cheaper interconnect I tried before. How can I get my hands on a quality XLR to RCA cable where the RCA end has the pins one and two connected like Ric recommended?
I would not jump on the Jensen just yet. Sometimes that can add more problems then solve. I have an extra balanced cable I am not using at the moment and I also have a pair of Cardas XLR to RCA and a pair of Cardas RCA to XLR adapters, also not using ATM, I would be happy let you try. These are his top of the line adapters called Clear. CG XLR Rhodium contact surfaces. Pure, non- magnetic, eutectic billet Brass, Gold and Rhodium over Silver platings. These connectors have a unique end shielding technique that blocks RF and Clock signal. http://www.cardas.com/adaptors.php Cardas (Purist Audio too) would most likely make what you would need.
I would be happy to bring my cable and adapter to your place for you to try if you would like.
I would not jump on the Jensen just yet. Sometimes that can add more problems then solve (...)
