Hi everyone,
I have been reading the forum and I didn't find anything similated to my doubts, so I will explain it here.
First of all, I don't have knowledge about audio configurations and similars so I will appreaciate any help on this.
I recently bought in Amazon the following mixer https://www.amazon.es/dp/B0B5GDZNYX?psc=1&ref=ppx_yo2ov_dt_b_product_details#customerReviews.
I connected to the mixer a few adapters from jack 6.35mm to 3.5mm in order to be able to connect from PC/consoles the audio cables.
After that, in the output connection, I used the jack cable 6.35mm to 3.5mm (which is included with the equipment) to connect to the soundbar (https://www.amazon.es/gp/product/B07HWQQGCR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1).
My point is, when I connect directly from the 3.5mm PC jack cable to the soundbar it works as usual, but, if I try to connect through the mixer I don't receive any audio from the soundbar.
I would like to know if any other gadget is necessary between the DAC162 (mixer) and the soundbar (output part).
I have been reading the user manual and I saw that the mixer and sound-card are drawn in the output connection, so I think it's related to what was last mentioned.
All of this is because I bought the mixer thinking that I will be able to hear all sounds (PC/console) at the same time through the soundbar, if this equipment is not for this or I need other additional equipment as I mentioned, I will appreciate if someone can confirm it.
Many thanks in advance,
Kevin
Kevin
