Speaker placement compromises in a less than perfect room
cjf
449
102
948
Hello,
I have the opportunity to place speakers in a room almost anywhere I choose but the room in question is not what I would consider ideal by audiophile standards. The room itself is a total of 24' long and for roughly half of that length it measures 15' wide but the other half is only 12' wide (Damn staircase). At the moment the speakers are located on the short wall which is 12' wide and they fire down the length of the 24' L space.
I sit about 8' away from the speakers and like the presence and intimacy it offers at this distance. The problem with the current speaker location is that it doesn't allow for much distance or prevention from side wall reflections. The speakers only have about 18" of space from the side wall and about the same from the rear wall if measured from the front face of the cabinet. Most of the side wall distance was achieved thru a fairly aggressive toe in angle so I'm not sure it counts for much. Despite the rooms short comings I feel somewhat fortunate in that my speakers have front firing ports which, I think, help make the speaker more tolerable to being placed in close proximity to the rear wall.
Based on some research I think I have found a better location for my speakers but would like to hear others opinions. I believe if I were to move the speakers to the long wall (24') it would all but eliminate any side wall reflections I currently have but I still wont gain much in terms of rear wall distance. Maybe an additional foot if I push it.
So, I guess my question is if I should be better off then I am today in a reconfigured room with almost no sidewall reflections, the same close rear wall placement and a seated position of roughly the same distance of 8'? I guess the other question is if having a shorter room is more detrimental to the sound than having less side wall reflections?
O'Yeah almost forgot, speakers in question are B&W 803 Diamonds
Thanks for any help you can provide
Sorry Mods, This may not be the best place for this question so please feel free to move it to a more appropriate area if required.. Thanks
I don't think I can offer you a lot of assistance on this because I am a "distance listener." If possible, I would place the speakers on the 15 foot wall and sit back much more than your present eight feet. I would use room/wall treatments to reduce side reflections of they were a problem.
Hello interesting suggestion. I pondered that one for a moment as well but wasn't sure how things would turn out for the right channel with the staircase being almost dead center of the room. The first step and associated incline of the staircase begins in a rather inconvenient location about 3ft away from a potential speaker location. Sitting furthur back in this configuration is certainly possible though. I wonder if there would be a potential for introducing odd room modes if one channel has an obstruction within a few feet of its path and the other channel being fairly free air in nature?
I can see this configuration offering the most flexibility for sure if it's determined that the staircase is not as big of an issue as I originally thought.
Thanks
One way to find out. . . .
Move your stuff around the room and listen to it!
True..:D
I guess I could pickup some elcheapo speaker cables that cover the distance of the room and see how it works out.
If your room is not a perfect rectangle, then there are no rules you can go by. Measurements and experimentation are your only tools at this point to figure out what works better.
A simple test may be to listen in mono. Use your current configuration and put one speaker where it is now, and move the other one further into the room. Then figure out a way to play one channel at a time of a mono source. Pretty easy to do if you have a PC and audio editing apps. Take your favorite music track and convert it to mono. Then select one channel vs the other and see which you like better.
BTW, listening tests shows that we are more critical of both speaker and acoustic problems in mono than stereo. So you will be arriving at better data this way.
