Schroder LT magnesium arm tube upgrade!
May 7, 2012
1,325
Seattle area
#1
I have had this arm for over three years now. Really had no complaints, but when Steve Dobbins told me he had an upgrade for it that I had to hear, it peaked my interest. After a few months I decided to go for it, and I am glad I did. The upgrade involves replacing the wood arm tube with a forged magnesium arm tube with a ceramic coating in my case. You can also get it with a clear urethane finish if you like. It also has a Teflon sleeve inside the arm tube for additional damping. Another change is the vertical axis bearing is upgraded as well.
The magnesium version has been in my system for a couple of months now. Been really busy lately, but finally have more time to listen and enjoy. This arm is quite a bit more resolving now. The noise floor has dropped a notch or two. Usually when you change something there is some sort of drawback but I don't hear any with this upgrade.
I will add photos when I figure out how.:) Getting an error when uploading for some reason.
XV-1
Active Member
May 24, 2010
1,556
7
38
Sydney
#2
the Schroder is the only tonearm that I have any interest in after I bought the Thales Simplicity II. the pivoted linear design in superb and it seems to work without a hitch.
The wood tonearm always left a small bit of doubt for some reason. I am sure the magnesium arm tube upgrade must be a great upgrade. And I see you use a technic motor as well - nice setup indeed.
Yes, we need pictures.
arnies
71
Austin, TX
#4
Congratulations Sean on having your LT upgraded to the Magnesium arm tube. Steve brought one for me to hear to compare to my LT arm with the wooden arm tube. I agree with you that I could not hear any drawback to the arm at all - just positive sonic improvements in resolution, speed, high end sparkle and better textures. I purchased that arm and had him upgrade my LT arm to the magnesium arm tube version.
Arnie
May 7, 2012
1,325
Seattle area
#5
Arnie
Thanks Arnie. I did not get to do a direct comparison like you did. Even so, it was quite obviously an improvement. The fact that you had the old arm upgraded as well, speaks volumes.
May 7, 2012
1,325
Seattle area
#6
Hi XV-1, The Thales Simplicity II is an interesting arm. I heard the first version at RMAF years ago. The sound was good. I would like to hear the newest version though.
You have quite the collection of turntables. Which table is the Simplicity II on?
XV-1
Active Member
May 24, 2010
1,556
7
38
Sydney
#7
Hi Shaun
I do like the old Japanese DD tables. The Simplicity II is normally on the TW Acustik, but I bought a Technics SP10 mk3 recently in the technics plinth to try the Simplicity on the Technics. I managed to do that a couple of weeks ago. Sounds great.
cheers
May 7, 2012
1,325
Seattle area
#8
Hi Shaun
cheers
Nice! I heard the original Thales arm at a show as well. I don't remember what cartridge it was using but remember it sounding very good. At the time I wanted one but it would not fit on my turntable due to it's design. It needed to be mounted very close to the platter which is a no go for the Technics.
5,051
29
48
Arnie
Hello Arnie,
What cartridge are using on your Schroder LT?
5,051
29
48
Hello Sean,
bonzo75
8,849
44
48
London
#12
Hello Sean,
His forum details have it - colibri. So both of them are direct drive with Schroeder LT. Technics and the Kodo. That's how I would end up if I had the money.
bonzo75
8,849
44
48
London
#13
Do both of you have this silver or copper wired? And the cost includes the wire running directly to the phono?
How easy is it to replace and armwand of an existing arm?
arnies
71
Austin, TX
#14
Hello Arnie,
Hi Ron,
I have 2 of the Schroeder LT arms, both with the Magnesium arm tube. One was a new one from scratch with the Magnesium arm tube and the second one is my original LT arm with wooden arm tube that has since been upgraded to the Magnesium arm tube version by Steve Dobbins. Both of my arms use the silver tonearm wiring. On one of my arms I use the Lyra Etna SL cartridge and the other arm has the Lyra Olympos SL cartridge.
Arnie
5,051
29
48
Thank you, Arnie!
5,051
29
48
In actual use what are the sonic pros and cons of the copper versus the silver tonearm wire?
  • Founded in 2010 What's Best Forum invites intelligent and courteous people of all interests and backgrounds to describe and discuss the best of everything. From beginners to life-long hobbyists to industry professionals we enjoy learning about new things and meeting new people and participating in spirited debates.
