Hi
I believe that Room treatment is the single most important addition one can make to a System .. Modest component in a good room systematically trumps great components in a not so good room. This said I also believe that it is best when one has the means to let a professional work its magic on your room. There are a few who are in this very Forum. If you can use their services This could well be the best investment youwould have made in your system... if you can't then prepare yourself to be very patient as Room Treatment is not an automatic .. Plug-n-Play thing more like Plug-listen-pray-berate-move-move some more-measure-listen, listen some more- unsatisfied-moving target , kind of affair ...
This site although very much oriented toward one particular brand of room treatment (ASC) does provide some very good pointers, a very good start.
I have NO vested interest in ASC or RPG I recommend however that BOTH be used in a system , most system require a certain amount of diffusion AND absorption.
This is the site http://www.tubetrap.com/...
I believe in using RPG in the front wall between the speakers and in the back wall as well , I also believe in seating far from the back walls,
http://www.rpginc.com/products/diffractal/index.htm
Frantz
Frantz
