Sablon Audio does, he purchased one last year.hola, alguien tiene alguna experiencia con el integrado riviera levante y lo compararia con pass labs
Well, like I said I could genuinely enjoy living with half of them however it is hard to replace the resolution of the Tungsram, once heard, and this is something I value for product development. That said, the Riviera has a special circuit / design which aims to correlate with human hearing rather than lab instruments so my preferences here might not be wholly representative in other contexts. I won’t however be spending more time on burn in / revisiting but will likely burrow deeper down the 1950s options; more handmade and more toxic materials ;-)Thanks SA. Sounds like there is only really one winner for you as far as your comments go, but with some reservations about improvements with some tubes after a longer burn in. Are you planning any further updates to these comments?
A surprise to me were your comments re the Yellow 6060, is quite the opposite of my experience. Just goes to show how different systems and ears can vary opinions.
Makes me think I should go back and listen to some of my other 12AU7's, to refresh my memory why I settled on the white 6060 all those years ago. Who knows it may even change my mind again
Great job though and interesting reading (for me at least!)![]()
I agree totally with your comment re measurements, if it were down to that parameter alone valve amps would, generally, not get a look in and what a travesty that would be. Thank goodness it is all about music, ears and personal taste.Just purchased today a pair of Mullard M8162 Gold Pin Valves to substitute the Russian Genalex in my Aqua La Scala,of which i am 100% sure will improve the SQ significantly, but keeping on thread I heard several headphone amps earlier this year at Headphoneauditions in Amsterdam, including the Riviera AIC-10 (balanced version) which was hands down the best by far, a truly class product which just gets everything right, maybe its the magic sauce in the special circuit design that correlates with the Brain as Mark previously mentioned,measurements/marketing certainly are not always the bencmark to concider when making a purchase, as I have found out over the years at great cost, hoping to make a Riviera purchase in the future.
Technical overview - Riviera
An audio amplifier must reproduce a signal with the highest fidelity for the human ear, not for instruments.www.rivieralabs.com
The Brimar 12au7 equivalent is 6067 btw, though I have often found e80cc to be a better sounding tube if your equipment can handle the extra current draw.
