Alexandre-I don't buy crusty old LPs. Usually crusty old LPs were also played with a crappy misaligned worn out cartridge and have irreversible groove damage.
Mine also leaves the web spots on the LPs, and I couldn't find a pattern. Apparently, it's the white plastic "lips" thingie that have to be inserted in the machine that bent up, and thus are not drying regularly.
Still, I don't mind. The results are fantastic enough. I just leave the LPs out drying out of their sleeves before I put them on the turntable.
mep, don't judge it before you see what it can do to crusty old LPs.
alexandre
AD was set up with two of their machines at Axpona 2013 (probably in case one broke). The demo guy wanted to know if he could clean one of my LPs. I gave him my Miles Davis MoFi LPs to clean. After waiting 5 minutes for it to go through the cycle, he pulls my LP out and it still has wet spots on it. He starts waving my LP around in the air in an attempt to dry it for me. I wasn't impressed. His excuse for why it came out with wet spots was that he didn't lift the LP straight up out of the machine. Is this a common problem?
Also, he told me that they now have a bunch of loaner units so that when your RCM breaks and has to be sent to Germany for repair, they have a loaner unit to send you. What is telling is that this program is necessary. I'm sorry, for $4K I'm not impressed.
I have to say that the fully automatic cleaning feature is especially addictive. Using my VPI is kind of like going back to a preamp without a remote control![]()
This aspect was the last drop. I added it to the lot of nice thinks you wrote in the PF review, imagined you listening to music while I am working hard listening to my VPI17and took the decision - my AudioDesk RCM will be delivered soon next week.
you can purchase new 'lips'. the old one's seem to shrink and lose their strength over time.
there is a couple of tricks you can try that will cause the older 'limp' lips to be more effective. over time they will bend away from the contact and allow more water to remain. turn them over and it should get slightly better.
you can find a 'twist-tie' wire and paper fastener, cut it to length, lay it flat and centered behind the 'lip' and push it into place. this will push up the lip and expand it slightly. you may need a bit of vaseline to get it into the slot.
as far as old and crusty Lps; don't judge a book by it's cover. sure; there is apparent damage that cleaning cannot fix. but remember, the stylus does not read the scuffs that are on the tops of the groove walls.....the stylus only cares about what is down in the grooves. there are many dull and scuffed Lps that play fine and quiet. and particularly mono records are almost immune to damage that you can see.....particularly with a mono cartridge.
if you have an RCM that is easy to use you will not tend to avoid 'crusty' Lps and you will find some gems.
My only experience with this machine was at Axpona 2013 and it was being operated by a guy who was supposed to be a pro. Let's start a list of people on this forum who own this machine and who have had their RCM break and have had to send it back to Germany for repair. So far, I know that Christian, Myles, and Mike are in this group. How many more owners do we have on this forum?
It was new design, most probably the designers will learn from their service experience. And if the sales in US are significant I think that at some point the distributor will have a stock of most needed parts and create a local service facility. I never sent my VPI to the USA when it needed assistance - I just got the parts from the factory.
I have a portable steam cleaner made for drapes my wife gave me for the tough jobs, it kicks arse.
Below is a quote from the manual of the Throess Phono Enhancer (phono stage) http://www.thoeress.com/en/phono-enhancer/
At the THÖRESS factory we clean records by letting them rotate (at 1 rpm) in the tank of
an industrial grade ultrasonic cleaner filled with demineralized water and a few drops of
concentrated dish cleaning liquid for at least half an hour. For best results it is advisable
to use a cleaner with an integrated heater programmed for 45 degrees Celsius. After this
procedure, the records are vacuumed on a conventional record cleaning machine such as
the Nitty Gritty. The gifted DIY hobbyist will be able to build the device needed for
rotating (up to 3) records through the cleaner bath with the aid of a barbecue motor. Our
cleaning methode will be found far superior to any other conventional cleaning method.
Any residual groove noise still experienced with records treated in this way will be due to
imperfections of the grooves and not to groove dirt. Do not hesitate to email us if you
require more details regarding this cleaning method.
